BuckSkin wrote in post #19021488
.I was reading the reviews on a lens and one guy made a claim that I had never before read in a review.
He rated the lens poorly and said that, although the lens was labeled 400mm, in actual use it was more like 250mm.
Any time there is that large of a discrepancy, it is not due to inaccurate specifications, but it is due to something often called "focus breathing." . It is nothing to worry about, because it only affects the field of view toward the extreme end of the focus range - at or close to minimum focus distance.
For instance, many 100-400mm zooms will actually be something like 105mm to 386mm, or something like that. . But if you are zoomed all the way out to 400mm and then focus on something real close, like just 3 feet away, then the angle of view may be only that which you would expect from a 250mm lens. . But when you focus on something further away it goes back to giving you the 386mm field of view that it normally provides.
This isn't really a fault of the lens or a deceptive practice by the manufacturers. . The very definition of focal length includes the qualifier "when focused at infinity". . Therefore, by definition, it is understood that a different angle of view may be realized when not focused at infinity, and that the further from infinity one gets, the angle of view has the greatest likelihood of falling away from that which it normally yields.
