Thread started 07 Mar 2020 (Saturday) 04:53
Question about XN-ViewMP ???
BuckSkin
Joined Nov 2014
Mar 07, 2020 04:53 |  #1
I asked this on the XN-View forum but must not have been clear enough in my question as the answers I got did not makes things very clear to me.
In XN-View "Settings" in the "General" section under the "File Operations" tab, down at the bottom, is "Keep original Date/Time", with three check-boxes to select or not.
My question is: In this context, what is XN-View's definition of "Original Date/Time" ?
Are they meaning the original Date Taken stamp; or, are they meaning the Date Modified stamp ?
I definitely do not want the Date Taken to be messed with, which to my way of thinking would be the "Original" time; but, I do want the Date Modified to be updated.
I hope I worded this in a way that makes sense.
Thanks for reading and all help is appreciated.
avondale87
thanks for whoever started this
Gallery: 1471 photos
Mar 07, 2020 05:14 |  #2
maybe just save a file to another name and look up the exif.
No matter what people tell you this might be the better way to go.
I can't help you as I don't have that program
Richard
BuckSkin
Joined Nov 2014
Mar 07, 2020 05:45 |  #3
avondale87 wrote in post #19022364 (external link)
Thanks; I will try a handful of sample files with the boxes checked and then unchecked and see how it goes.
The reason this is sort of important is that my back-up program has an option, "Skip Files with Same Time Stamp"
If I leave that option unchecked, it takes forever and a day to make a back-up; but, with it checked, I am beginning to suspect that additional EXIF information that I have added is not making the trip.
BuckSkin
Joined Nov 2014
Mar 07, 2020 06:35 |  #4
Thanks again; I copied a few test files to a test folder, made note as to both the Date Taken and Last Modified; and, leaving all the boxes checked as they had been all along, I performed a few changes to the metadata.
I checked the time stamps and neither had changed.
I then unchecked the boxes and performed some more changes to the metadata.
This time, when I checked the EXIF, my Date Taken were unmolested and the Last Modified had been updated to match the time of the operation = just like I wanted.
I did the same with digiKam and changed the settings to behave the same way.
Now, I just need to make a run with my back-up program with the "Skip Files with Same Timestamp" unchecked and that should get things all back on track.
Stiga
Gallery: 908 photos
Joined Dec 2015
Mar 07, 2020 06:45 |  #5
FYI, the original "date taken" is always retained (unless the EXIF data is completely removed). I don' kmow why photo viewers don't make use of it. Just upload ar file to Exif Info.org (external link) and you will see it entitled Date/Time Original
Martin
I'm not a gear guy but I have a tons of software :-)
1,018 views & 2 likes for this thread, 3 members have posted to it and it is followed by 3 members.
1092 guests, 117 members online
