anitaw2 wrote in post #19024662
... I have a simple set up: Canonn 6D, 85mm f1.8, 70-200mm f4 and 35mm f1.4 and 1 Canon Speedlight 430. ... I've read that the Pocket wizard, Yongnu and Gottix are good. can anyone suggest what I should get for just a simple user-friendly trigger for 1 flash?
I'd avoid PocketWizard, there have been issues with radio interference and Canon EX speedlights. It's one of the reasons Canon created the RT gear.
Yongnuo's YN-622C/YN-622C-TX combo would work for low cost with your 430EX, if it's a 430EX II or 430EX III-RT. But if you only have a 430EX, you won't have full control (no M power levels) with either the 622, Godox, or Phottix TTL triggers. So, a lot depends on which 430 version you have.
Just me, but I'd recommend a US$110 Godox TT685-C or $180 V860II-C speedlight and the Godox XPro-C or Flashpoint R2 Pro II-C transmitter (either is $70), vs. add-on Yongnuo triggers; or, if your 430 is the 430EX III-RT, a Canon ST-E3-RT or Yongnuo YN-E3-RT transmitter. Built-in radio transceivers are much more convenient, robust, and convenient to use than ones you add onto the foot of the flash.
But the Godox gear is my first choice, because their system
is more extensive than any of the others and offers many more expansion options. And the V860II-C
offers the advantage of a li-on rechargeable battery pack that can drastically simplify battery handling for an all-day shooter. A single pack can roughly take the place of a dozen AA batteries. And with the combination, you'd have TTL, HSS, Zoom, and group control.
If you want to go cheaper and don't need TTL/zoom control, you could also just get a $60 Godox TT600
for off-camera use.
