steve18 wrote in post #19045071
... Manual focus better but still not sharp. ... 70-200 F4L which is better than the 24-70 but still not spot on
This statement really concerns me. When using live view for focusing, it's the very same sensor for focus and capture. If the camera is stable (tripod) and you're focusing accurately in live view, the images should be spot on.
Regarding AF, I have a 6D and the AF system is what I like the least on that camera (compared to my 5DIII). The (only!) 11 AF points and only the center point being cross-type, is the main crippling factor on that camera (IMO). But, when using the center point, I've always had great results with the 6.
Still, I can't let go of that bad feeling about the manual focus test. The picture above with the brick wall and (lots!) of foliage makes me wonder if that was manually focused or using AF. With all of the surrounding branches and many of them closer than the wall, did the camera simply mis-focus. If it was manually focused, then what were you focusing on? You've got that large red box, but it encompasses a lot at different distances. The second picture might be the concrete patch below, but it's not the same picture magnified (different EXIF data).
According to DXOMark, the sharpest settings for the camera/lens are with the lens set at 24mm and f/4. How about trying that and a simpler subject? That lens doesn't rate the highest, but still, the image that you posted looks way, way worse.
The other question I'm wondering about is what kind of post-processing has been applied? Are we looking at a JPG out-of-camera or did you shoot in CR2 and then how did you convert it for posting here?
Coming from crop to full frame I have a lot to learn!
Framing differences aside, and even with different MP densities, you should expect reasonably sharp images out of either sensor size.
Image hosted by forum (
1038413)
© dasmith232 [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Image hosted by forum (
1038414)
