Thread started 27 Apr 2020 (Monday) 08:07
10-22 on 1D Miv?
Atrawick
Gallery: 6 photos
Post edited over 3 years ago by Atrawick with reason 'change question '.
Apr 27, 2020 08:07 |  #1
Looking for wide angle lens for real estate. Will be using a 1D M4.
umphotography
grabbing their Johnson
Gallery: 21 photos
Apr 27, 2020 19:02 |  #2
there was a video on You tube showing how to remove a plate and then use a 10-22 from 14-15mm on a 1DMKIV
I decided to use the Tokina 11-16 F/2.8....It does not Vignette at 15mm...so 15mm worked well and I never went past 15mm
Less than 15mm and I believe you have to worry about hitting inside of camera
I had a crop in the bag at the time so it f=got double duty use
Mike
www.umphotography.com (external link)
Facebook (external link)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Apr 27, 2020 19:19 |  #3
Generally 1 series bodies cannot take ef-s lenses without altering the lens.
Dave3222
Gallery: 178 photos
Joined Jul 2013
Apr 27, 2020 19:56 |  #4
A third party lens designated for Canon crop cameras still have an EF mount and can be used without fear of hitting the mirror. You will get vignetting as you zoom in, as with the Tokina 11-16, but it will not entend into the camera body.
Atrawick
Gallery: 6 photos
Apr 27, 2020 21:53 as a reply to  @ Dave3222's post |  #5
so any 3rd party lens for crop sensor will fit the 1dm4?
gonzogolf
Gallery: 561 photos
Apr 27, 2020 22:15 |  #6
Atrawick wrote in post #19054050 (external link)
No. You need to check each one.
wyntastr
Gallery: 47 photos
Joined Mar 2012
Apr 27, 2020 22:19 |  #7
It should as long as it has an EF mount, although I'm not an authority on the subject.
I used a Tokina AT-X 124 PRO DX 12-24mm F4 on my 1DmIII and it worked fine, although it did vignette over 13mm. Here's an example:
IMAGE: https://live.staticflickr.com/65535/49827646313_36646c975e_b.jpg
IMAGE LINK: https://flic.kr/p/2iV6​Hhe  (external link) Nissan GTP ZX-Turbo (external link) by Jonathan (external link), on Flickr
1D X - 6D - 1D Mk III - Rokinon 8 fisheye - EF 17-40 f/4L - EF 50 f/1.8 Mk I - EF 85 f/1.8 - EF 70-200 f/4L - EF 80-200 f/2.8L Magic Drainpipe - EF 300mm f/2.8 IS L - EF 500mm f/4 IS L - EF 100-400L
gonzogolf
Gallery: 561 photos
Apr 27, 2020 23:41 |  #8
If you are serious about real estate you might consider getting a ff body. Used 5DII or 6D's are really affordable now. The 1D4 is kind of worst option, a cropped body, but without access to lenses made or crop bodies. It's a well regarded sports and wildlife body but not suited for your intended purpose
Choderboy
I like a long knob
Gallery: 185 photos
Apr 28, 2020 03:19 |  #9
They will all fit. Is it worth using them is the question.
Details of two EF-S lenses used on full frame. They should be a lot better on 1DIV obviously.
EF-S 24mm STM on Full Frame
https://photography-on-the.net …showthread.php?​p=17321739
I suggest reading post #3
Modified EF-S 10-18 STM on 5D3
https://photography-on-the.net …read.php?t=1388​461&page=1
Dave
Image editing OK
Dave3222
Gallery: 178 photos
Joined Jul 2013
Apr 28, 2020 19:08 as a reply to  @ gonzogolf's post |  #10
Which non-Canon manufactures make an EF-S mount? They may designate for Canon EF-S but the mount is still EF.
Dave3222
Gallery: 178 photos
Joined Jul 2013
Apr 28, 2020 19:11 as a reply to  @ Atrawick's post |  #11
ONLY Canon makes an EF-S mount. Third party lenses designated for crop cameras still have an EF mount.
1,514 views & 6 likes for this thread, 6 members have posted to it.
10-22 on 1D Miv?
1497 guests, 138 members online
