Jtorpeide wrote in post #19068622
Update:
It will get printed, my boss insist... It will hang in the lunchroom. I guess it will be a reminder of where i started
Do you have any software to process this image with and what format was it shot in? Before he has the print made, you can still do some work with it, primarily pushing your Shadow detail up a bit to reveal some detail in the city and background mountains. It's entirely probable that your boss is viewing the image on a monitor that is too bright to be displaying photos accurately and is going to be thoroughly disappointed in a print. Before having it printed at a size that would be hung in the room, I'd urge them to get a simple 4x6 'proof' print made first since those are reasonably cheap.
Back to the image itself, I would also agree w/ Galt as a pretty good breakdown of things and just add a little more detail to a couple of items:
- With landscape scenes, you will generally want to have a fair amount of detail through the entire image; which translates to "more Depth of Field" and is accomplished with a smaller aperture (larger f/ number). Shooting between f/8 and f/16 is the general sweet spot range to be looking at. There are a number of starting posts here on the site that cover that stuff in much more detail.
- Handheld shooting of landscapes can certainly *be* done, but one of the reasons most are shot from a tripod is that shutter speed is one of your primary light controls, related to my point above. Smaller apertures require getting more light by lengthening the exposure rather than keeping a short exposure to mitigate hand shake. If you're likely to hit situations like this going forward, get yourself a middling travel tripod and just toss it in the trunk. This point can break out into a whole rats nest of other discussion around size, cost, material, etc; but, a simple mid-range, knockoff brand travel unit should support your M just fine and offer you some good function while you're learning whether you're even going to make these sorts of shots often enough to spend for a real, solid unit.
- Really get back into knowing and understanding the exposure triangle and what effect each of those has with digital media; it sounds like you've done in the past, but may want to just brush back up on them. Getting to know your meter and really taking to heart how it works will help avoid this type of underexposure you see in the above scene in the future.
If you're willing to give access to the source file for the image, though a Dropbox link or other share service, and give the Ok, I and some others can show you some edit suggestions that you could use for figuring out how you want to handle results like this in the future.
Your framing is good, horizon aside
, and one of the biggest things to have down for photography. Being able to identify and display your subject well is much more important than "how" you capture it, for the most part. So, you're already "up" there, just need to keep working at it and practicing to get those results YOU want! Keep at it and keep sharing/critiquing.
