Thread started 07 Jun 2020 (Sunday) 03:21
7D Card GB Limitations ???
BuckSkin
Joined Nov 2014
Jun 07, 2020 03:21 |  #1
I have a CF-to-SD adapter that we use with the 7D.
I have a 64-GB Delkin "Advantage" SD card that we use in the adapter in the 7D.
When the card is formatted/empty, the RAW/Large jpeg "count" shows 999.
I tried three Transcend 32-GB cards and each of them showed 799; I might not have ever caught it had I not been messing with the 32-GB cards.
To my way of thinking, if a 32-GB card holds 799 images, then a 64-GB should hold 1598, some 600 more than the 7D is showing.
In the card-reader, the capacity gauge says 58.+ GB for the 64-GB card.
I stuck the 64-GB card in the 7DMkII just to see what it said = I didn't format it; I left it formatted for the 7D; allowing that the 7DMkII (if memory serves) is 24MP, whereas the 7D is 18MP, the 7DMkII showed 1299 images available; I will take that as the identical Delkin 128-GB card in the 7DMkII shows 2598 = exactly twice the 64-GB.
To eliminate the possibility that it may be a limitation of the adapter, I stuck the adapter/SD card in the 7DMkII CF slot and got exactly the same 1299 as it showed in the normal SD slot.
I don't have a 64-GB CF card to compare and see if it shows the correct number.
Could someone who has a 7D and a 64-GB CF card, please check and see how many available RAW/Large jpeg it shows for an empty/formatted card ?
Is the 7D limited as to card capacity ?
It will not even recognize the 128-GB SD card in the adapter; it just says reload the card or try a different card.
Thanks for reading and all help is appreciated; I hope I didn't lose anyone in all that confusion.
Choderboy
I like a long knob
Gallery: 185 photos
Post edited over 3 years ago by Choderboy.
Jun 07, 2020 04:44 |  #2
Doesn't the 7D have 3 digits in the 'shots remaining' window?
I know the 7D2 has 3.5.
Dave
Image editing OK
Choderboy
I like a long knob
Gallery: 185 photos
Jun 07, 2020 04:49 |  #3
Yep, that's the problem. You'll need to get half a digit installed.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2020/06/1/LQ_1048695.jpg
Image hosted by forum (1048695) © Choderboy [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2020/06/1/LQ_1048696.jpg
Image hosted by forum (1048696) © Choderboy [SHARE LINK]
Dave
Image editing OK
BuckSkin
Joined Nov 2014
Jun 07, 2020 13:27 |  #4
Choderboy wrote in post #19075020 (external link)
Thanks for the illustrations and thanks for solving the mystery.
That "half a digit" business threw me off for a bit; but, I take it you mean the 7DMkII has the ability to display a "1" in the first position, but it can't display anything else.
I didn't even know that the top screen displayed the remaining count before you posted those illustrations; I always look at the bottom/right of the rear screen; I can kind of see it; whereas, I must resort to the big magnifying glass to read anything on that top screen.
I looked at the 7DMkII with the 128 GB card; and, sure enough, while the back screen was displaying the correct 2598, the little top screen shows 1999.
The 7d only shows 999 in both positions, so it must only have capability of three digits on the rear as well.
I believe you have hit the nail on the head in this mystery.
I guess that once the count drops below 1,000, then the 7D will count them down correctly from there on.
You said "You'll need to get half a digit installed" ; is that even possible ? If so, how would I go about it ?
Choderboy
I like a long knob
Gallery: 185 photos
Jun 08, 2020 01:59 |  #5
BuckSkin wrote in post #19075225 (external link)
No, I was just joking.
Regarding the '3.5' digit, that is real terminology and yes, you're right, it can only be off, or 1.
3.5 digits provides 0 to 1999 instead of 0-999 of 3 digits.
You are also right regarding the count working correctly once there is only space for 998 images.
Dave
Image editing OK
BuckSkin
Joined Nov 2014
Jun 08, 2020 02:32 |  #6
Choderboy wrote in post #19075489 (external link)
I may screenshot and frame this; me being right twice in one discussion and even getting credit for it.
I appreciate you shedding light on this scenario; it may have taken me years to stumble on the possibility that 999 was as high as the 7D could count.
I figured it was some limitation or other that was actually limiting the capacity of the card; we have an old HP camera that, no matter what capacity SD card we put in it, it formats them to be 1-GB; put a 16-GB card in it and as soon as you turn the camera on, it becomes a 1-GB card. (that's not many pictures, by the way)
I had about half-hoped that there was a firmware hack or someother that would add a digit or so.
Thanks for answering.
Canon ­ Amateur
Gallery: 50 photos
Post edited over 3 years ago by Canon Amateur.
Jun 08, 2020 04:34 |  #7
BuckSkin wrote in post #19075499 (external link)
In fact there is a hack that does add a few digits at the back screen.
It is called MagicLantern.
https://www.magiclante​rn.fm/ (external link)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2020/06/2/LQ_1048904.jpg
Image hosted by forum (1048904) © Canon Amateur [SHARE LINK]
On the top plate you see [999]
On the back screen you see 50709
I had to switch to JPG only, S
I've used an empty 64GB CF-Card.
I do not have a 128GB CF to check if the digits extend to 6 digits.
MagicLantern even shows how much space is left on the CF Card; 59.5 GB.
Windows reports the CF-Card as 59.6 GB with 59.5GB available.
As an added bonus you can check the shuttercount in the Debug section.
I suggest you start reading the FAQ.
https://wiki.magiclant​ern.fm/faq (external link)
Canon EOS 1Dx / 5D4 / 5Dsr / Fujifilm X-T4 / Lytro illum
BuckSkin
Joined Nov 2014
Jun 08, 2020 06:16 |  #8
Canon Amateur wrote in post #19075532 (external link)
Thanks for that.
I have procrastinated trying Magic Lantern for years; I have even gotten so far as downloading it for our T3s a couple times, but never quite got the nerve to go any further.
Several years ago, I at first had the impression that it actually installed in the firmware --- and maybe it did at the time; but now, it is my understanding that it resides completely in a memory card and removing the card removes all traces of it from the camera --- is that right ?
It appears you have it and know a bit about it; what other beneficial features does it add for a non-video "still" photographer ?
I intend to read through those FAQs again, but I would appreciate some experienced user feedback as well.
rgfrison
Gallery: 180 photos
Jun 08, 2020 06:31 |  #9
I thought it might just be a simple math solution but my raw files vary in size from 18 mb (black screen) to 33 mb in the few dozen I checked. If you figure at 32mb per file it is 1000 for a 32gb card and 2000 for a 64gb card. I assume the exposure, detail, ect account for the file size variation.
Randy
apersson850
Obviously it's a good thing
Gallery: 35 photos
Jun 08, 2020 06:44 |  #10
Press the INFO button instead of the Q button and you can see the correct count on the rear display. Pressing Q will just mimic what's shown on top, but the INFO screen shows some other camera information, including the real number of images that it predicts can be stored on the card.
Anders
Canon ­ Amateur
Gallery: 50 photos
Jun 08, 2020 08:10 as a reply to  @ BuckSkin's post |  #11
The thing MagicLantern (ML) does to the camera is enabling a "bootflag".
If a memory card is "bootable" then the additional software on that memory card wil be loaded.
If ML is missing on that bootable card then the camera cannot continue any further.
So always leave ML on a bootable card or disable bootdisk on the card.
When using Windows, take a look at:
https://pel.hu/eoscard​/ (external link)
ML enables me to use "auto ETTR".
And "silent picture" in full resolution. M mode and LiveView only.
This enables me to take pictures at a classical concert without being noticed.
Camera on a tripod, disable Beeps (also in ML), LiveView on, half press to focus, press Set to ETTR, and then a quick halfpress to shoot silent.
When focussing a Magic Zoom box appears and shows a 3x magnification with a rudimentary SplitScreen.
SplitScreen tries to mimic the focus circle (I used to have on my old Canon AE-1) where the top and bottom half lign up on focus.
Useless for sports but perfect for classical concerts.
ML also lets me overlay a cropmark in LiveView and playback pictures. In some cases it is usefull.
I once made a custom cropmark to assist me in a specific situation.
I did experiment a little bit with Dual ISO and Advanced Bracketing, but I am not using it at the moment.
You might even try to seach on Youtube for some more info on MagicLantern.
And for some fun:
https://www.youtube.co​m/watch?v=CmjeCchGRQo (external link)
https://www.youtube.co​m/watch?v=RCT-YMgjm9k (external link) (viewers discretion is advised)
All in all: Silent Picture is the 'killer app' for me.
BuckSkin
Joined Nov 2014
Jun 08, 2020 14:03 |  #12
Canon Amateur wrote in post #19075589 (external link)
Thanks.
I guess the key word there is "bootable" ; the camera will always still work normally with a plain old memory card, right ?
I have had some experience with a similar program, CHDK, on a little pocket camera, Canon SD880 I think; it gave that little camera a ton of useful features.
I still have it in a drawer with about a dozen other Canon pocket cameras; since all the non-photographer photographers have been using their phones instead, I can pick these little pocket cameras up at yard sales and swap meets for little of nothing.
BuckSkin
Joined Nov 2014
Jun 09, 2020 08:48 |  #13
That is a good source; thanks.
BuckSkin
Joined Nov 2014
Jun 09, 2020 14:21 |  #14
apersson850 wrote in post #19075568 (external link)
Press the INFO button and you can see the correct count on the rear display.
Thanks; it even shows the GB capacity.
2,073 views & 4 likes for this thread, 5 members have posted to it and it is followed by 2 members.
1087 guests, 116 members online
