I couldn't find a thread about screen brightness, although I'm sure one exists, so.....
How can I determine if my screen brightness is set correctly so that when viewing pictures on a different computer, the images are not too bright/dark?
fordmondeo I was Soupdragon in a former life. More info | Jun 07, 2020 04:28 | #1 I couldn't find a thread about screen brightness, although I'm sure one exists, so..... Vaginator9000
gonzogolf dumb remark memorialized More info | Jun 07, 2020 05:40 | #2 There are two routes to go. The first and best way would be to purchase calibration software which will let you set your monitor up so that your monitor will match the output for other displays and prints. The down and dirty method is to google online monitor calibration sites, there are a number of sites that have brightness test strips, where you can adjust your monitor so that you can see the page as it should be. It's not perfect but its quick and free.
Redcrown Senior Member 351 posts Likes: 47 Joined Dec 2008 More info | Jun 07, 2020 15:18 | #3 There is no way to adjust your monitor brightness so images look good on other computers. That's because the brightness of other computers will be all over the board. For the most part, other computers will be way too bright because most will be at the "factory" setting.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 3 years ago by Wilt. | Jun 07, 2020 21:19 | #4 Look at this on your monitor. You should be able to distinguish each tonal area from each other. Redcrown was right on, in the comment about most other monitors won't be adjusted properly because they are set to factory brightness and contrast, which are set to look good in the bright retail environment in which so much monitor selection is done. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Nick5 Goldmember More info | Jun 10, 2020 09:15 | #5 For Example, my 2017 iMac 27 “ 2TB Fusion Drive the Brightness level has 16 squares or “Chiclets” to choose from. Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
| Latest registered member is semonsters 1455 guests, 128 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
