FORUMS Photo Sharing & Discussion Architecture, Real-Estate & Buildings
Thread started 26 Jun 2020 (Friday) 03:15
Bracketing photos best settings
serggio
Joined Sep 2016
Jun 26, 2020 03:15 |  #1
Whats the best settings for Bracketing photos for real estate photography INDOOR
3 Bracketing photos OR 5 Bracketing photos?
Mode AV OR M?
ISO?
Metering mode?
Shutter speed?
Any help will be important.
Thanks in advance.
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jun 30, 2020 20:33 |  #2
As with all photography there are no best settings.... there are only the settings that work for that exact moment/place. Light changes throughout the day so if I tell you the best settings now they won't be right an hour from now.
serggio wrote in post #19083876 (external link)
Yes, 3 or 5 or 4 are all good. depends on how extreme the scene is, what software you use and how you like to work. Try 3; If you don't like how it turns out try five.
Mode AV OR M?
Yes these are both good. Which d you prefer?
ISO?
Assuming you are using a tripod then your camera's base ISO as that should give the least noise. If you are not using a tripod then the lowest ISO while still maintaining a proper exposure.
Metering mode?
Others may offer different advise but I would suggest spot metering so you can measure the brightest highlights and the darkest shadows and set your bracket to cover that range.
Shutter speed?
No one can tell you what shutter speed you need because....
1. We have no way of knowing how much light there is in the scene you are shooting,
2. Or what your other settings are (Aperture and ISO)
3. Plus you are shooting 3-5 different exposures so different settings.
You meter the scene and then set the shutter speed for the exposure you want.
Dan Marchant
serggio
Joined Sep 2016
Jul 02, 2020 15:13 |  #3
Thank you Dan Marchant
Pigpen101
Joined Mar 2017
Jul 02, 2020 15:32 |  #4
Dan covered it. I would add to shoot RAW. Also, take 5 or even 7 images. You may not need them but it's a lot better than needing to go back to the place to take more shots. Especially if you need to bother a resident or a real estate agent.
790 views & 1 like for this thread, 3 members have posted to it and it is followed by 4 members.
974 guests, 108 members online
