As others have said, your focus looks absolutely perfect - right on the eye, which is exactly where anyone would want it to be. . I do not know why you said, "missed focus" in the thread title, when the focus appears to be perfect. . I mean, if you didn't want the snake's eye to be in focus, then what did you want to focus on instead?
If you wanted more of the snake in focus, you could have stopped down to increase your depth of field ....... but then that would mean that the leaf litter on the forest floor would be more in focus than it is, which would not make for a very attractive image.
If you wanted the snake's entire head to be in focus, then you could have moved more to your right and shoot from that angle instead, as then the part of the snake's head that the camera "saw" would all be on the same focal plane, more or less.
Often times, how much of your subject is in focus is just as dependent on the angle you shoot from as it is on aperture and depth of field. . A change in settings does not solve most problems with thin depth of field shots. . Camera positioning - the angle your subject is at relative to the camera - does solve many thin depth of field issues.
Here's a pic I took of a snake of similar size, with the same lens you used, at the same f5.6 aperture that you used. Because I shot from the side of the snake, instead of head-on or quartering in, the entire part of the head that the camera "saw" was in focus. . Unfortunately, I still didn't get a very good image, as my lens was fogged over badly due to the extreme Pennsylvania humidity.
Image hosted by forum (
1056718)
© Tom Reichner [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Aesthetic decisions can be really tough when your subject is right there in a lot of leaf and needle debris.
. There's only so much you can do, and it looks like you did pretty well, considering the conditions that you had to work with.
."Your" and "you're" are different words with completely different meanings - please use the correct one.
