FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 29 Jul 2020 (Wednesday) 16:00
Desmond QR plate on RRS BH-55 head
downhillonwater
Joined Feb 2020
Post edited over 3 years ago by downhillonwater.
Jul 29, 2020 16:00 |  #1
My Desmond clamps don't fit my newly purchased BH-55 head. The mortise on the underside of the plate is a hair too small for the tenon on the top of the ballhead.
Anyone have experience and for this? I'm contemplating doing a little machining on the Desmond mortise....
Thanks!
Flickr https://www.flickr.com​/photos/downhillonwate​r/ (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Post edited over 3 years ago by CyberDyneSystems.
Jul 29, 2020 17:33 |  #2
Is the QR clamp a lever or a screw knob?
I ask because the first RRS clamp I ever owned (circa 2006) would not work with a number of my existing plates.
The problem in this case was it simply would not open far enough to allow them to slide in.
In that case, it was a simple fix changing one aspect of the screw to allow it to open further.
CDS' HOT LINKS
downhillonwater
Joined Feb 2020
Jul 29, 2020 20:16 |  #3
I've messed up the terminology in my first post. Apologies.
I bought the BH-55 without a clamp with the intention of adding a Desmond. The undersized mortise is on the underside of the Desmond screw clamp I'm planning to add. Used the Desmond's for a while and really like them. Thanks for your help.
peter_n
Post edited over 3 years ago by peter_n.
Jul 31, 2020 15:10 |  #4
The socket in the BH-55 stem is 1/4"-20 thread size. Desmond clamps come with 3/8"-16 sockets, ordinarily a problem like this can be solved with an adapter that you screw into the 3/8"-16 socket. It doesn't work in this case because one end of the adapter has a lip with cutouts for a screwdriver blade. I also use a lot of Desmond clamps and tried this solution myself just now with a RRS BH-55. What you need is a 1/4"-20 threaded bolt with a flat head cap. That should work.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2020/07/5/LQ_1057081.jpg
Image hosted by forum (1057081) © peter_n [SHARE LINK]
~Peter
jmckayak
Aug 08, 2020 09:42 |  #5
Maybe use a Dremel tool to enlarge the tenon socket?
eddieb1
Joined Apr 2013
Post edited over 3 years ago by eddieb1.
Aug 08, 2020 13:04 |  #6
jmckayak wrote in post #19105697 (external link)
That’s what I had to do. Dremels are wonderful things in the right hands. Just make sure you modify the clamp and not the ball head. Cheaper to replace the clamp if things go sideways.
downhillonwater
Joined Feb 2020
Aug 11, 2020 08:52 |  #7
It's good to know others have encountered this. I came to the same solution and enlarged the Desmond slot. Working great now. Since Desmond is making excellent parts to go (mostly) on other company's supports, they might consider this....
peter_n
Aug 11, 2020 13:53 |  #8
Obviously I completely misunderstood the OP's problem. Below are a couple of my Desmond clamps with the Heavy Duty version on the upper left, the regular version to its right and the RRS clamp that came with the head at the bottom. The RRS screw (1/4"-20 threaded screw with a flat head cap) works fine on these Desmonds.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2020/08/2/LQ_1058603.jpg
Image hosted by forum (1058603) © peter_n [SHARE LINK]
~Peter
968 views & 3 likes for this thread, 5 members have posted to it and it is followed by 2 members.
1470 guests, 131 members online
