Thread started 04 Aug 2020 (Tuesday) 21:01
Disappointed with 1.4 Extender on 400mm
Larry ­ Johnson
Joined Sep 2011
Aug 04, 2020 21:01 |  #1
I love the canon 400mm prime on the 7D2 body. Auto-focus speed is increadable for action photography. Was so disappointed with the AF speed with the canon 1.4 III extender added. It slowed down considerably and did much more hunting to find focus compared to no extender. Is there anything that can be done to increase AF speed. I"m shooting wildlife in natural light. Has anyone else noticed the same significant decrease in AF speed.
Ain't Nature Grand!
Shooting 7D2 with Canon 400mm, f/5.6.
60D, canon 18-135 EFS, and 1.4 extender in the bag.
tomj
Aug 04, 2020 22:06 |  #2
I have the same setup as you, and my experience has been the same. I've found the extender usable for perched or wading birds, but terrible for flight shots or other action. I had pretty much stopped using it for a couple of years, but tried it earlier this year when I felt I could use the extra reach shooting a male harrier. Out of maybe 100 shots I only got several keepers - I would have been better off leaving it off and just cropping tighter.
Instagram (external link)
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Aug 05, 2020 00:23 |  #3
Larry Johnson wrote in post #19104085 (external link)
I love the canon 400mm prime on the 7D2 body. Auto-focus speed is incredible for action photography. Was so disappointed with the AF speed with the canon 1.4 III extender added. It slowed down considerably and did much more hunting to find focus compared to no extender. Is there anything that can be done to increase AF speed. I"m shooting wildlife in natural light. Has anyone else noticed the same significant decrease in AF speed.
It would help if you told us which one of the Canon 400mm prime lenses you are talking about.
I've used the Canon 400 f2.8 with the 1.4 and it worked marvelously with the 1.4 extender on it, no matter which body it was on. . It focused just as fast and accurately with the extender as it did without it. . At least I couldn't tell the difference. . And the image quality was just as good with the extender as it was without it - can not tell any difference at all, even when pixel peeping at way beyond 100% pixel views.
I've also used the Canon 400mm f5.6 with the 1.4 extender, and did not like it at all. . It did slow autofocus down a little, and the image quality was ever so slightly poorer with the extender than it was without it. . The 400mm f5.6 and the 1.4 extender are a poor combination, in my experience, because it isn't exactly as good in every way as the naked lens without the extender.
So based on my experience, if you are using the 1.4 extender with the f2.8 lens, and it is not working flawlessly, then something is probably wrong with one of the pieces of gear involved.
If you are using the extender with the f5.6 lens, and it is not working flawlessly in every way, then I think that there may be nothing wrong with the gear, and that you should probably expect some slight compromises to come into play when you use the extender.
I haven't used the 1.4 extender with either of Canon's 400mm f4 lenses, so if that is the lens you are talking about, I don't have any experiences to share with you. . Sorry.
AcademicNomad
Gallery: 27 photos
Aug 05, 2020 00:49 as a reply to  @ Tom Reichner's post |  #4
I will serving the above very detailed comment. If your lens is the f5.6 version, you will struggle with BIF when used with TCs.
I believe 7D2 gives you only the centre focus point when you attach a TC to a 5.6 lens. That in itself is problematic to track erratic/fast movements
Desire to learn; a camera & a few other things.
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Aug 05, 2020 06:06 |  #5
Remember your camera needs light to focus, it's why the aperture is always set to it's widest point when focusing before stopping down if needed to take the photo.
Extenders increase the lenses focal length, but they do not change the size of the aperture. This means using a 1.4x extender on a lens with a maximum aperture of F2.8 makes an F4, and a lens F4 becomes a F5.6, and a F5.6 becomes an F8.
While the 7D can focus really well at F2.8 and F4, at F5.6 it will be starting to struggle, and while it can focus at F8 (a lot of earlier cameras couldn't) it will be really struggling to find an area of sufficient contrast with the limited light it has to work with.
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
John ­ Sheehy
Aug 05, 2020 07:35 |  #6
F/8 is not a favorable open f-ratio for AF on the 7D2 in OVF mode. OVF AF abilities are marginal at f/8 in many cameras, especially older ones, even if they officially support f/8. You need good contrast and light, and minimal confusion of depths, to get reliable AF.
John ­ Sheehy
Aug 05, 2020 07:41 |  #7
tomj wrote in post #19104100 (external link)
... or using Live view. Many cameras have better f/8 AF in Live view, but that makes operation with narrow angles of view very difficult, without a loupe, and most older cameras have significant LCD lag.
tomj
Aug 05, 2020 07:55 |  #8
John Sheehy wrote in post #19104221 (external link)
I've used live view in difficult focusing situations of relatively static subjects, but for me at least, it's impossible for BIF, which was the case with the harrier I mentioned.
tomj
Aug 05, 2020 07:59 |  #9
Tom Reichner wrote in post #19104124 (external link)
He has the 5.6 version in his gear list at the bottom of his post.
John ­ Sheehy
Aug 05, 2020 10:19 |  #10
Moppie wrote in post #19104188 (external link)
It goes beyond the lower light levels with a higher open f-ratio. The 7D2 will AF very easily at f/5.6 on a B&W pattern in pretty low light, but if you use f/11, no matter how much you increase the illumination, you still won't get focus. Most (if not all) of my DSLRs can focus at f/8, even if they're not supposed to (if you trick them), even indoors with the blinds closed, but none will focus out in the sun at f/11, although f/9 has worked marginally (f/6.3 + 1.4x). In OVF AF modes, DSLRs seem to fall off a cliff at some point between f/8 and f/11, in the ability to focus at all, no matter how much light. Most types of AF except pure contrast-detect sensor-based AF rely on bundles of light coming to focus at various angles, which is where f-ratios come into play. Even for contrast-detect, though, diffraction and aberrations can make the assessment of focus slower.
Larry ­ Johnson
Joined Sep 2011
Aug 05, 2020 17:56 as a reply to  @ John Sheehy's post |  #11
Hey, thanks for all the replies. I didn't realize that anyone had replied because I didn't receive and email notice like I do for posts that I didn't create. At any rate, I have the f5.6 and looks like others have experienced the same slow focus condition. Such a shame. Would a 1D body produce the same problem, or is it a lens issue.
Ain't Nature Grand!
AcademicNomad
Gallery: 27 photos
Aug 05, 2020 18:37 as a reply to  @ Larry Johnson's post |  #12
You will have better success with 1Dx and up. I don’t know about the older 1D bodies; never tried 5.6 lens with a TC on my 1D iv.
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Aug 05, 2020 19:26 |  #13
Larry Johnson wrote in post #19104489 (external link)
The focusing deficiencies that I described in my previous post occurred on every body I tried it with. . This includes the 1D Mark 4. When you have a slow lens with a small aperture and then you put an extender on it, you can't reasonably expect fast focus tracking like you would get with no extender.
It would be interesting to see how the 400mm f5.6 and the 1.4 extender perform on one of the two new mirrorless bodies, the R6 and the R5. . I think that because they do focusing based on sensor readout, that their focusing systems aren't limited by light the way contrast-detect focusing systems are. . So maybe with one of those cameras you would get perfectly fast and accurate autofocus, despite the fact that you would be using an adaptor to mount the extender to the camera.
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Aug 06, 2020 00:59 |  #14
All focusing systems are impacted by the level of light. The difference is a contrast detect systems becomes less able to quick focus and then just stops working altogether, while a phase detect (like in mirrorless cameras) just gets slower and takes longer to focus.
A 1Dx in theory would work better, but even at F8 it's not going to perform as well it does it at larger apertures. An R5 or R6 would also keep working at F8, but again it's ability to find focus will slow down.
John ­ Sheehy
Aug 06, 2020 03:51 |  #15
Moppie wrote in post #19104599 (external link)
Mark II and especially III for sure, but I doubt that the original 1Dx is much (if any) better at f/8 in marginal conditions. In perfect conditions, like a BIF against deep blue sky, it should drive the AF faster, though.
2,540 views & 18 likes for this thread, 12 members have posted to it and it is followed by 7 members.
1689 guests, 140 members online
