Thread started 13 Aug 2020 (Thursday) 11:27
Should I buy RF
willie45
Aug 13, 2020 11:27 |  #1
Hi
I have ordered the R6 and I'm patiently waiting. I have my EF lenses: 16-35 f4, 50mm f1.8, 24-70f4L IS, 100mm macro and 100-400.
I'm wondering if I should buy the 24-105 RF. I wonder if this move would this be an actual upgrade or just a convenience to save me carrying the 100mm as well?
I could use the 24-70 f4 on both my R6 and 5ds, and thats a sensible option, but I keep hearing how good this new 24-105 is and it is designed for the R series, I guess, so I'm assuming it would have advantages. I imagine IQ would be about the same? OTOH do I really need another 24-70 range lens? Hmmm.
Any advice?
Windsun33
Joined Mar 2012
Aug 13, 2020 12:20 |  #2
I have watched at least a dozen videos on YouTube about the adapter with EF lenses, and 4-5 RF to EF comparisons on the RF and R6. None would seem to justify spending the money for the RF if you already have an EF equivalent. One video poster said that the IIS worked slightly better with the RF, but not near enough to justify spending the money if buying the same type lens.
My first real camera was a Canon F1. That was a long time ago.
wimg
Aug 13, 2020 18:09 |  #3
willie45 wrote in post #19108386 (external link)
Hi
Any advice?
The RF 24-105L is the same to slightly better than the EF 24-70 F/4L IS in teh overlapping range, and quite a bit better than the EF 24-105L versions. It is also cheaper than the EF versions, funnily enough.
So, if you want more reach, it certainly is a valid option to replace the EF 24-70 F/4L IS with the RF 24-105L. Same or better IQ wih more range, be it a little heavier.
As to the macro: I don't know whether you own the L or the non-L version, but even so, up to and including F/4 the macros both beat the RF 24-105L at 105 mm as far as I can see, thereafter it is much of a muchness I would expect. Having said that, the macro has as its widest aperture F/2.8, unlike the RF 24-105L, and does macro right to 1:1. The RF 24-105L only goes to 1:4.16 (at 45 cm focusing distance). So, if real macro is a requirement and/or F/2.8, I would suggest you'd hang on to your macro lens. If you do not need macro and/or F/2.8, by all means go with the RF 24-105L. It comes recommended.
BTW, personally I hated the EF 24-105Ls, basically because they did not perform in difficult light circumstances, as in low light, low contrast, especially at the long end, resultign in mushy images. The RF 24-105L does not have this issue, and I actually love it. I had a similar experience with the EF 100L Macro, BTW, also mushy in low light/low contrast at "normal" focusing distances. At the time that was for me the reason to get another EF 100-400L Mk I rather than the 100L Macro, because it was better at all FLs in those conditions. The 100 non-L macro I personally never liked that much, because of the rendering, which is where the 100L Macro was better. However, that is of course personal preference to a large degree.
For macro I prefer the 180L Macro, the non-WA TS-Es, EF 135 F/2L, M-PE 65, and EF 100-400L I and II, with Canon D500 achromatic close-up lens.
Anyway, HTH, kind regards, Wim
kf095
Out buying Wheaties
Gallery: 64 photos
Aug 13, 2020 20:10 |  #4
As for as I remember RF L lenses are better optically than EF L.
I'll update my 24-105 f4 IS L from EF to RF.
I also remember how earlier on it was mentioned about RF mount allowing to make smaller lenses.
Unfortunately it didn't happened. Canon went to the opposite way and made overpriced, huge and heavy RF lenses.
Big disappointment to me as RP user. So, 24-105 F4 IS L is the only RF L which makes sense to me.
I have 50 1.8 MKI and it is OK on RP. Large EF lenses are kind of OK on RP as well. Focus is working fine.
willie45
Aug 13, 2020 22:43 |  #5
Thank you all for your help. I’m undecided. I feel that I have 24-70 range adequately covered and maybe I should leave things as they are.
Also TBH as I’m getting pains in my old age and I sometimes wonder if primes might be the way to go for me. I feel that having the 50mm and 100mm (non-L) as well as the 24-70 I could as easily sell the zoom and buy a 24 mm prime and maybe a 14mm MF and be happy and less burdened. Im not sure if I’d miss the zooms for general photography.( I also have a 100-400 Tamron and. Canon 400 f5.6L for wildlife which is my main interest these days)
Anyway, I guess if I was upgrading to another DSLR I doubt I’d be even considering my lens situation and it’s just that this new RF range has made me start to wonder ......
kf095
Out buying Wheaties
Gallery: 64 photos
Aug 13, 2020 23:01 |  #6
I'm kind of true RF photog. :) Started with FSU RF and returned to it in 2012. I went through many RF cameras and I have original 50 1.8 Canon RF lens. I have few RF lenses. Leica Summarit-M 35 2.5 and Voigtlander Nokton 35 1.4 MK II. They are awesome on RP.
IMAGE: https://live.staticflickr.com/65535/50123321588_4fabb39d13_b.jpg
I don't know how newest Canon RF cameras will be with original RF lenses like I have. R seems to be not so good as RP. But manual focusing with original RF lenses on RP beats RF focusing on Leica original RF cameras. With RP and original RF lenses I'm able to keep in focus people walking towards to me. Can't do this with Leica RF cameras. RP shows entire DOF area, Leica has just tiny focus patch in the middle.
Size of original RF lenses is very small. It is smaller than 40 2.8 EF on fatty EF to RF adapter.
wimg
Post edited over 3 years ago by wimg.
Aug 14, 2020 04:18 |  #7
willie45 wrote in post #19108694 (external link)
Actually, that is fine, as is wondering :). It is probably a good idea to wait until the RF line of lenses is fleshed out some more, before making any decisions. There is an 85 F/2 Macro coming as well, after all, and likely quite a bit more.
As to a 14 mm MF lens: Samyang / Rokinon does an excellent 14 mm AF lens for the R series these days, which is not a big lens, and not (too) expensive either. That could be worthwhile considering as well if you are looking for an UWA.
Kind regards, Wim
willie45
Aug 14, 2020 15:09 as a reply to  @ wimg's post |  #8
Yes, Wim, the Samyang 14mm is on my definties list no matter what else I buy ;-)a
kf095
Out buying Wheaties
Gallery: 64 photos
Aug 14, 2020 16:18 as a reply to  @ wimg's post |  #9
I hope Samyang will come with same lenses they have for Sony mount. Compact and light 35 and 24.
14mm is half a kilo, 35mm is well under 100g, which is very impressive achievement for AF lens.
raytracer
Joined Jun 2020
Aug 16, 2020 01:17 |  #10
I've compared RF 24-105 to EF 24-105 v1 and v2. Edge sharpness and CA is clearly better on RF version, and center sharpness at tele also wins. For video, the RF has much better stabilization than EF v1, quiet and no jitter, which is equal or slightly better than EF v2. Besides that, I like it being shorter and having a customizable control ring.
idkdc
Joined Oct 2014
Aug 16, 2020 21:42 |  #11
My opinion: yes, buy the RF. I have used many copies of the 24-70 F4 and found it a much inferior lens to the 24-70mm f/2.8L II. It seems that the new RF 24-105L F/4 should be closer to the latter lens and gives better reach.
I like big cinema cameras and I can not lie
You other brothers can't deny
willie45
Aug 22, 2020 05:54 |  #12
Thank you both for your help. I will save my pennies for the RF 24-105.
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Aug 29, 2020 06:39 |  #13
willie45 wrote in post #19112867 (external link)
I really like it.
Image Editing OK
Mybludog
Gallery: 112 photos
Joined Nov 2013
Post edited over 3 years ago by Mybludog.
Sep 05, 2020 05:45 |  #14
Can someone tell me the differences between some of the RF lens please?
RF 24-70 f2.8 v RF 28-70 f2
and
RF 85 f1.2 v RF 85 f1.2 DS
Just not sure why they've got these lens that seem nearly the same
Just like a dung beetle......russellpringlephotogra​phy (external link)
@russellpringlephotogr​aphy
gossamer88
"something else"
Gallery: 94 photos
Joined Aug 2014
Sep 05, 2020 06:44 |  #15
Mybludog wrote in post #19120376 (external link)
and
RF 85 f2 v RF 85 f2.8
The f2 zoom was introduced with the EOR R. It is a beast of a lens. I guess they were still working on the 2.8 for the trinity set.
The other 85 is a 1.2 (not 2.8) and the new one doubles as a macro and is more budget friendly.
EOS R5 | EOS R7 | iPhone 12 Pro
RF 100-500mm | RF 100-400mm | RF 800mm F11 | RF 600mm F11
RF 24-240mm | RF 50mm 1.8 | RF 35mm 1.8 Macro | RF 16mm 2.8
1,818 views & 3 likes for this thread, 9 members have posted to it and it is followed by 3 members.
Should I buy RF
1457 guests, 129 members online
