Thread started 16 Aug 2020 (Sunday) 05:35
Adorama Flashpoint R2 Pro Mark II Flash control transmitter benefit
RDKirk
Adorama says I'm "packed."
Joined May 2004
Post edited over 3 years ago by RDKirk.
Aug 16, 2020 05:35 |  #1
Just want to point out the single main reason I've been using the Adorama (exclusive) Flashpoint R2 Pro Mark II Flash control transmitter for Godox/Flashpoint flash units.
I've been in certain venues where the other Godox transmitters have been bedeviled by misfires caused by radio interference. In some cases, I may get two or three misfires for every one successful flash. The Godox system may be particularly sensitive to interference, because in several places where I'd used Paul C Buff's CyberCommander without problems, I had loads of problems with the Godox Pro (Mark I) controller.
The Adorama Flashpoint R2 Pro Mark II Flash control transmitter has a frequency scanning feature that checks for interference and identifies the clearest channels. You then set all the equipment to one of those channels.
I have found this to work wonderfully in all the situations I'd previously run into misfire problems.
allengambrell
Joined Mar 2016
Aug 17, 2020 17:51 |  #2
And you can also turn off the Multi mode!
ThreeHounds
Gallery: 129 photos
Joined Mar 2014
Post edited over 3 years ago by ThreeHounds.
Aug 18, 2020 10:58 as a reply to  @ allengambrell's post |  #3
It also converts the last used TTL flash power value to manual with a button press.
It also functions as a transmitter properly when mounted on the hot shoe and using a 1st gen R2 Transmitter as a remote shutter trigger with an R2 receiver attached to the remote port. I tend to use this a lot.
5D MkIII | 7D | Bronica ETRS
EF 24-105 f/4 L | EF 85mm f/1.8 USM | EF 17-40 f/4 L | EF 70-300 f/4 L | Sigma 35 f/1.4 Art | Zenzanon 105 f/3.5 | Tamron SP90 f/2.8 Di Macro VC USM
Blanton James Photography (external link)
chrispy94
Joined Dec 2014
Jul 01, 2021 09:57 |  #4
I'm very glad I found this thread, great info! I am moving to Godox/Flashpoint and was contemplating a used trigger.....I know not to look for the older model just because they're cheap.
Thank you!
1,138 views & 2 likes for this thread, 4 members have posted to it and it is followed by 5 members.
1454 guests, 128 members online
