Thread started 25 Aug 2020 (Tuesday) 20:18
Extender for Sigma 150-600 Sport w/Canon 7D2
Larry ­ Johnson
Joined Sep 2011
Aug 25, 2020 20:18 |  #1
Is there an extender that will function between the 7D2 and sigma 150-600...and how's the image quality. I don't mind being limited to a single AF point, and I realize there will be loss of f-stop.
Ain't Nature Grand!
Shooting 7D2 with Canon 400mm, f/5.6.
60D, canon 18-135 EFS, and 1.4 extender in the bag.
dangermoney
Joined Mar 2019
Aug 25, 2020 21:02 |  #2
Yup:
https://www.sigmaphoto​.com/teleconverter-tc-1401 (external link)
FS: Canon G1X Version 1 with B+W filters
https://photography-on-the.net …/showthread.php​?t=1529660
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Aug 25, 2020 21:38 |  #3
Kenko pro 300 if you can even find one any more. I used that very often with the 7D2.
Larry ­ Johnson
Joined Sep 2011
Oct 30, 2020 19:40 |  #4
TeamSpeed wrote in post #19114911 (external link)
...and you used it between a Sigma 150-600 Sport lens and 7D2?
Ain't Nature Grand!
Choderboy
I like a long knob
Gallery: 185 photos
Post edited over 3 years ago by Choderboy.
Nov 05, 2020 04:47 |  #5
Lens firmware matters.
7D2 and 150-600 Sport with EF 1.4TCIII worked when the Sport was released.
Sigma then did firmware update and the EF 1.4TCIII no longer worked.
EF 1.4TCII worked before and after update.
No longer worked means you cannot take a photo, "lens communication error" or similar message is displayed.
This was my experience a few years ago. I don't know how many firmware updates have been released since.
Don't assume this was intentional action by Sigma. The 500 f4 Sport did not work with EF1.4TCIII on release but after later firmware update it did. EF1.4TCII worked before and after. Again, further updates have been released.
I found it was not worthwhile to use 1.4TC on 150-600 Sport and 7D2.
It was worthwhile on 1D4 if you can tolerate the AF performance drop.
ie, with 1D4 and cooperative static subject the image quality was good. Otherwise better off cropping a bare lens shot.
7D2 image quality with 1.4TC was not worthwhile.
Dave
Image editing OK
John ­ Sheehy
Nov 05, 2020 05:02 |  #6
Larry Johnson wrote in post #19114881 (external link)
f/9 AF is going to be very marginal on the 7D2, unless you use live view. It will only work well with bright light and good contrast, and simple depth structure, and will be slow.
If you use a non-reporting converter (or a taped one) AF will be faster, and more AF points may be available, but faster AF sometimes becomes AF that overshoots, and hunts back and forth, or "locks" at the wrong position. You also lose correct EXIF reporting; your files will have no indication of the actual focal length and f-number.
If mirror-less is in your future, the newer ones can AF combos that would be dead in the water on a DSLR. With my R5, it will AF my Sigma 100-400/5-6.3 accurately at 1120/18, and even somewhat quickly if the lens is almost in focus from the last shot (you can identify the subject in the viewfinder before it is in focus). If I tape the converter closest to the camera to hide it, it focuses faster and often hits target, but may jump off of focus more easily or shoot past it occasionally.
John ­ Sheehy
Nov 05, 2020 05:26 |  #7
Choderboy wrote in post #19147895 (external link)
It's time for converters with a USB port, and multi-position switches for custom TC modes and simple non-reporting. You could enter your own hunt speeds, and max full drive speeds, optimized for your lens and AF system. It could have body-side TC pins to see a TC behind it, for correct EXIF info, if you want it. Any switch position could use a different firmware.
TCs are such an integral part of focal-length-limited photography, but somehow they don't get designed with flexibility in mind.
It is becoming more apparent to people using modern mirror-less cameras that much of the impression that that many people have had that "cropping is better than TCs" is more a result of poor AF than of additional optical problems with TCs. Perfectly focused optics with a TC (and with sufficient stability) give more subject detail, even with sub-perfect main optics and TCs that might reduce global contrast a tad, or have slight halos around fine details. You can hide most of that in post, if you need to, but you can't pull out real details that were never captured, because they happened inside of big pixels (and yes, I think that even 7D2 and even 90D pixels are large, for the best optics).
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 3 years ago by TeamSpeed. (2 edits in all)
Nov 05, 2020 05:29 |  #8
Larry Johnson wrote in post #19145546 (external link)
I had the contemporary version but yes, on the 7D2 and 5D3. In good light, AF was snappy and locked on, and the results were quite good.
John ­ Sheehy
Nov 05, 2020 05:55 |  #9
DG or DGX? The older DG has better compatibility with recent cameras, as the DGX (at least with the earliest firmware) crash cameras like the 7D2, 90D, and R5, in my experience.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Nov 05, 2020 07:39 |  #10
The old ones back from around 2008 or so, I never saw good reviews on their newer ones so I stayed away. I sold them when I got my MKIII Canon TCs and wish I hadn't.
Capn ­ Jack
Gallery: 2961 photos
Nov 05, 2020 07:48 |  #11
John Sheehy wrote in post #19147909 (external link)
That may work if you know how to program proportional–integral–​derivative controllers (PID controllers or three-term controller) because you want the focus to move quickly with minimal overshoot. The parameters for this will vary with different lenses, so you would need different setting s for different lenses made by the same manufacturer. Lenses made by other manufacturers would have different settings for their lenses of a given focal length. As teleconverters (TC) are simply a fixed lens with some electronics to pass information (either analog or digital), there isn't much incentive for the TC vendors other than Canon to do all that. Canon has optimized their TCs to work with their lenses and cameras.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Nov 05, 2020 07:51 |  #12
I have had my combos hunt a few times here and there, but hardly ever have had them overshoot the target and stop OOF. The hunting is more annoying because a lens like the 150-600 with a TC takes a bit of time to rack back and forth.
The 1.4x Kenko, Sigma lens, and 7D2 did pretty well together when I had these (I no longer have any of these now).
Larry ­ Johnson
Joined Sep 2011
Nov 11, 2020 14:28 |  #13
Thanks for all the replies and discussion. Are you referring to the canon converter when you mention EF 1.4TCII.
I own the canon 1.4 III converter and I'm well aware it doesn't work. I also just bought a kenko 1.4xpro300 and it also doesn't work; i.e. won't let me take a photo.
Maybe I should just get a pro body and even longer lens. Can't get closer to my subjects because of their in the water and boats aren't allowed.
Ain't Nature Grand!
John ­ Sheehy
Post edited over 3 years ago by John Sheehy.
Nov 12, 2020 04:41 |  #14
Larry Johnson wrote in post #19150648 (external link)
Kenko "DGX" converters are designed to hijack the lens-body communication instead of just reporting themselves to the lens. They are magical on the older cameras that they are compatible with, like my 7D and 6D , but crash most recent cameras, like my 7D2, 90D, and R5. The older "DG" ones work by protocol, and are far more versatile, working with pretty much all lenses, with no protrusions in the front.
The DG TCs don't tell the lens to AF at a greater speed, though, with certain lenses and bodies as allowed when using a Canon vIII TC, and need to be taped (and lose their proper EXIF info) to allow faster AF speed. It would be nice to have a 3rd-party TC that didn't tell the AF to slow down, but still reported the correct f-number and focal length in the EXIF.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Nov 12, 2020 14:50 as a reply to  @ Larry Johnson's post |  #15
There are several kenko versions of their TC for Canon. Which specifically did you buy? Can you take a pic of the product or box it came in?
2,060 views & 6 likes for this thread, 7 members have posted to it and it is followed by 5 members.
1689 guests, 140 members online
