FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 07 Sep 2020 (Monday) 12:18
Heavy duty tripod for macro and time lapse?
Windsun33
Joined Mar 2012
Sep 07, 2020 12:18 |  #1
There seems to be at least 345 brands of tripods out there, and I have been struggling to make sense of it all. What I am looking for is something that is good for DSLR and mirrorless (such as Canon R5) with heavy lens and maybe flash, so probably in the 3 to 5 kg range as a minimum.
1. Something that can go low, like to almost ground level, and up to around 5 feet high.
2. Very good wind resistance (I currently have 3 medium to high end travel tripods, and all fail at this).
3. Weight of tripod is not much of an issue, as this is not one I will be hiking with, usually just driving to with SUV.
4. Would like to keep the total price, including ball or pan head under around $600.
5. Is OK with getting wet and sitting in water up to a couple of feet deep.
Any recommendations welcome.
My first real camera was a Canon F1. That was a long time ago.
vision35
Gallery: 26 photos
Post edited over 3 years ago by vision35. (4 edits in all)
Sep 07, 2020 17:49 |  #2
Its been 20 years since I purchased my Bogen3021 Pro and its still working great. Of course I care for my tripod like an expensive car. Fewer leg sections in my opinion makes a tripod stronger ( fewer leg sections are probably larger in diameter) or more steady or less wiggly. If your exposing the tripod to salt water you may want to avoid aluminum or plan on cleaning it well after use. I'm looking at these tripod models to hike and use a 150-600mm. For some reason I may buy the Benro GA158FB1 Go Classic 4-Section Aluminum Flip Lock Tripod supports up to 17.6 lb that can be extend up to 66.3 inches. The others I may consider are. Manfrotto Befree Advanced Special Edition 4-Section Aluminum Travel Tripod with 494 Center Ball Head for Sony Alpha Cameras, Lever Leg Locks, 17.6 Lbs Capacity. Manfrotto MT190X3 Aluminum Tripod 15.4 lb of gear.
Windsun33
Joined Mar 2012
Sep 07, 2020 20:41 as a reply to  @ vision35's post |  #3
One I was looking at is the Induro, but recent reviews seem to indicate they might have some quality control issues. https://www.bhphotovid​eo.com …t203_2_grand_st​ealth.html (external link)
I would prefer a carbon fiber type with no metal. I had an aluminum one a while back, and it got just a tiny dent in one of the legs and that made it very hard to extend. You might be right about the number of leg sections - on comment on YouTube said his multi-leg thing had trouble with wind.
This is another I was looking at - a bit pricey but has good reviews https://www.bhphotovid​eo.com …_3372_Rapid.htm​l/overview (external link)
sawsedge
Joined Dec 2011
Sep 09, 2020 18:37 |  #4
FLM makes great stuff. Their second gen tripods are solid. Have a look at their largest... https://www.flmcanada.​com …ct/flm-cp38-l4-ii-tripod/ (external link).
Where this fails your list is the price. You can step down in size if they will still meet your needs, but it's hard to get something very solid and keep the price that low.
- John
Windsun33
Joined Mar 2012
Sep 09, 2020 19:16 as a reply to  @ sawsedge's post |  #5
The FLM looks interesting, though it is a bit over what I was hoping to spend. I see that Adorama has it for around $720.
Nick5
Sep 10, 2020 08:44 |  #6
Windsun33 wrote in post #19121815 (external link)
I have the GIT Induro 304 L. No issues. Very stable with a GMB2 Gimball and 400mm lens.
The Smaller unit you are looking at may fit your needs.
Canon 5D Mark III (x2), BG-E11 Grips, 7D (x2) BG-E7 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Sep 10, 2020 10:25 |  #7
Ive got a few induro's and love them. They have become my go to brand. It would be a shame if QC was slipping.
CDS' HOT LINKS
John ­ from ­ PA
Joined May 2003
Post edited over 3 years ago by John from PA.
Sep 11, 2020 12:10 |  #8
Crazy as it seems, consider dropping back a few decades to wooden legs. https://woodentripods.​wordpress.com/ (external link)
See https://www.riestripod​.com/large-format-photography (external link), and specifically the H100 model. This thing will survive water readily and is impervious to mud and sand. Check you “low” requirements.
If you are handy, you might Google a surveyor tripod. They can be in wood, usually up to 72” and are very stable. Typically you have to do something for the mount since the thread is much larger for a surveyor’s instruments than a 1/4-20. Usually very cheap!
peter_n
Sep 11, 2020 13:41 |  #9
John from PA wrote in post #19123576 (external link)
Not crazy at all; they are vibration free. I use a Berlebach Report 302 when I can and they're a bargain at around $250 from Germany. They're very sturdy and it's one of the tripods I can use my Arca Swiss C1 geared head on. Great platform for the Fotoman 617 panoramic camera. The only downside is that wooden legs are relatively heavy.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2020/09/2/LQ_1063195.jpg
Image hosted by forum (1063195) © peter_n [SHARE LINK]
~Peter
Windsun33
Joined Mar 2012
Sep 11, 2020 15:11 as a reply to  @ peter_n's post |  #10
Interesting - had not really thought about the wooden tripods. Weight is not really an issue, since I will be able to drive very close to most of the places I would want to set up in my off-road SUV. Will look into them a bit more.
1,083 views & 5 likes for this thread, 7 members have posted to it and it is followed by 5 members.
1253 guests, 116 members online
