Thread started 09 Sep 2020 (Wednesday) 10:06
Sensor scratch
mjHession
Gallery: 6 photos
Sep 09, 2020 10:06 |  #1
Is this a sensor scratch, or is there like a protective layer above the sensor. There was some dirt on the sensor, i used some compressed air to remove.and this scratch was made in the process.
It doest seem to have any effect on IQ, but just curious what impact it may have and if it is repariable.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2020/09/2/LQ_1062817.jpg
Image hosted by forum (1062817) © mjHession [SHARE LINK]
Primary Gear - M6 Mark II; Σ f/1.4 Trio (16, 30, 56) - Σ 150-600mm f/5 - 6.3 C
Sigma 1.4x & 2x
Full Gear List - Feedback
gjl711
"spouting off stupid things"
Post edited over 3 years ago by gjl711. (2 edits in all)
Sep 09, 2020 10:13 |  #2
I'm not sure what you are calling a scratch. All I see is a lot of dust. I would think that the two big ones are visible especially as the aperture closes. I'm not sure what type of compressed air you used but might want to try a bulb type blower instead, something like a rocket blower (external link). Can you highlight the thing you see as a scratch?
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
mjHession
Gallery: 6 photos
Sep 09, 2020 10:32 as a reply to  @ gjl711's post |  #3
These marks seem to not be removable. But as far as I can tell have no effect on IQ, or at least no obvious ones. Ive tried a few different test backgrounds and can see anything.
I'm using a general air compressor with regulator, running around 40 psi on the regulator.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2020/09/2/LQ_1062822.jpg
Image hosted by forum (1062822) © mjHession [SHARE LINK]
Sigma 1.4x & 2x
bumpintheroad
Self-inflicted bait
Gallery: 21 photos
Joined Oct 2013
Sep 09, 2020 10:46 |  #4
I was always told to never use compressed air to clean the sensor. Don't use anything stronger than a squeeze bulb.
I would try a wet sensor cleaning and see if the marks go away. Otherwise, you're either going to need to pay for a new sensor or just live with the problem.
-- Mark | Gear | Flickr (external link) | Picasa (external link) | Youtube (external link) | Facebook (external link) | Image editing is okay
xinvisionx
Gallery: 51 photos
Sep 09, 2020 10:47 |  #5
Do not used compressed air to clean a sensor. NEVER. EVER. Damage to the sensor can occur.
If those marks on the sensor cannot be removed, they are affecting image quality.
My name is James ~ Gear
gjl711
Sep 09, 2020 11:37 |  #6
Cleaning with a compressor is fine assuming that you have it properly outfitted. I would not use the same compressor that I use to run my air tools though. Though it does have moisture scrubber, it also has a lubricator so in essence I would be spraying a fine mist of oil onto the sensor. In addition, the hose I use is rather dirty. Not a problem for air tools but I don't want to shoot crumbs at a camera sensor at a rather high speed.
The particles you highlighted are most likely dust that has stuck. It's time for a good wet cleaning. There are many way to do so none clearly better than another but here are a few links to cleaning methods. Choose what works best for you. Link (external link) / Link (external link) / Link (external link) .
I prefer using a pec pad on a swab with Eclipse solution but have used other methods as well. The Eclipse/Pec Pad methods seems to work best for me.
::Gear::
chuckmiller
Gallery: 65 photos
Joined May 2012
Sep 10, 2020 09:22 |  #7
I am almost certain I once read somewhere on this board the sensor has a glass cover.
Retired from Fire/Rescue with 30 years on the job - January 2019
gjl711
Sep 10, 2020 10:00 |  #8
chuckmiller wrote in post #19123030 (external link)
There are several filters in front of the image sensor. Take a peek at THIS (external link), it shows a typical SLR sensor setup. However, the filters are not something that are easily replaceable. Odds are if you sent it in for servicing, Canon would swap out the entire sensor assembly (external link).
::Gear::
1,071 views & 1 like for this thread, 5 members have posted to it and it is followed by 6 members.
Sensor scratch
1170 guests, 114 members online
