Thread started 30 Sep 2020 (Wednesday) 06:32
New computer specs
GyRob
Sep 30, 2020 06:32 |  #1
Perhaps I should have asked in here first but it's on it's way now just wondered if it seems ok mostly for photo editing I do have extra external drives as well.
Rob.
Intel Core i9-10900K CPU, 10 Cores / 20 Threads, 3.7 - 5.3GHz
Case: Fractal Design Define R6 USB-C Case - Black
Graphics Card: NVIDIA GeForce GTX 1660 Super 6GB Graphics Card
CPU Cooler: Noctua NH-U12S CPU Cooler
Thermal Paste: Prolimatech PK-3 Nano Particle Thermal Paste
Motherboard: Asus TUF GAMING Z490-PLUS (WI-FI) Motherboard
Memory: 64GB DDR4 2666MHz Memory (4 x 16GB Sticks)
OS Drive: 500GB Seagate Barracuda 510 M.2 PCIe Solid State Drive
Solid State Drives: 1TB Samsung 870 QVO Solid State Drive
Additional Hard Drives: Seagate 2TB BarraCuda 7200RPM Hard Disk
Optical Drive: Lite On External DVD+/-RW Drive
Power Supply: Corsair RM550x 80 PLUS Gold 550W PSU
PSU Silencing: AFG-PSU Anti-vibration Power Supply Gasket
Sound Card: Onboard High Definition Audio
Internal Card Reader Drive: Akasa 17 in 1 USB 3.0 3.5" Internal Card Reader
Additional USB Ports: Inateck 2 Port PCI-E USB 3.0 Hub Controller with Internal USB 3.0 20-PIN Connector
Operating System: Windows 10 Home 64-bit
"The LensMaster Gimbal"
Colorblinded
Gallery: 18 photos
Post edited over 3 years ago by Colorblinded. (2 edits in all)
Sep 30, 2020 07:13 |  #2
:lol: yeah, that should do the trick
Setting aside the fact that I'd have made some different choices, the only thing that really stands out to me is the power supply.
I'd have put more power supply in it since that CPU is known to be quite hungry. Not much headroom there, but you don't have a particularly demanding GPU so it should be OK.
http://www.colorblinde​dphoto.com (external link)
http://www.thecolorbli​ndphotographer.com (external link)
John ­ from ­ PA
Joined May 2003
Post edited over 3 years ago by John from PA.
Sep 30, 2020 07:34 |  #3
Should be a nice machine. I do see that “Colorblinded” mentioned the power supply. Looking up the specs I don’t see that as a big issue. You can review th finding at https://www.guru3d.com …k-processor-review,5.html (external link) where they found 295 watts for a multithreaded load. Keep in mind that is for the entire “representative” machine so it might be slightly different than yours but is offered up as a guideline.
I also note that the 550w rating on the Corsair PDU is the “continuous” rating.
Colorblinded
Gallery: 18 photos
Sep 30, 2020 09:10 |  #4
John from PA wrote in post #19132165 (external link)
If it weren't such a good power supply I'd be more concerned but those Corsair supplies are solid.
Still if you load enough drives in to that system and hook up enough USB devices and have the CPU and GPU running full out with the rest of the system being reasonably taxed you're coming closer to the PSUs rating than I'd typically choose to.
GyRob
Sep 30, 2020 10:03 |  #5
Many thanks guys,
I doubt I will ever put it under to much pressure most use will be just photo files I don't leave my external drives in all the time there just a backup .
Rob.
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Sep 30, 2020 14:36 |  #6
Did you look at a Ryzen 3900X or 3800X?
They seem to be offering easily the best performance per dollar at the moment.
Otherwise it looks like a really sound system. We have a Fractal Design R5 and R6, both with the solid side panel. It's a nice case, has great filters and with solid side panel is very quite.
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
chuckmiller
Gallery: 65 photos
Joined May 2012
Sep 30, 2020 17:36 |  #7
Rob, what program do you photo edit with?
Retired from Fire/Rescue with 30 years on the job - January 2019
GyRob
Oct 01, 2020 02:44 |  #8
Moppie wrote in post #19132331 (external link)
To be honest iv always had Intel so had an idea of what i thought i wanted so stuck with that system .
Rob.
GyRob
Oct 01, 2020 02:48 |  #9
chuckmiller wrote in post #19132388 (external link)
I mainly use Affinity or PS 5 but only do basic PP no Layers and mostly jpeg I try to get them about right in the camera it's a hobby to me :)
Rob.
Scrumhalf
Gallery: 158 photos
Joined Jul 2012
Oct 01, 2020 02:55 |  #10
That computer is loaded to the gills lol.. you should have no problem doing just about anything you want with it.
Sam
5D4 | R7 | 7D2 | Reasonably good glass
If I don't get the shots I want with the gear I have, the only optics I need to examine is the mirror on the bathroom wall. The root cause will be there.
Colorblinded
Gallery: 18 photos
Oct 01, 2020 12:23 |  #11
GyRob wrote in post #19132552 (external link)
Rob.
It'll be plenty of computer either way :-D
GyRob
Oct 01, 2020 15:15 |  #12
Hi Guys /Galls
Well it came today and up and running I loaded Photoshop and Affinity and both open in 2 seconds when i drop a file onto the short cut ,topaz denoise is 1 second to open and on standard setting takes 15 seconds to process a 14mb file .
Videos looks great and so is the sound with music files
The computer is absolutely silent all in all as good as i could wish for :) it takes 12 seconds to show the screen when i switch it on so not too bad.
Rob.
904 views & 2 likes for this thread, 6 members have posted to it and it is followed by 4 members.
New computer specs
1473 guests, 130 members online
