Totally new to using RAW files. Easiest to use, functional RAW software with no subscription? I noticed some of the info here is pretty old. I don't mind purchasing retail software. Was looking at Elements and maybe Corel.
Oct 08, 2020 07:39 | #1 Totally new to using RAW files. Easiest to use, functional RAW software with no subscription? I noticed some of the info here is pretty old. I don't mind purchasing retail software. Was looking at Elements and maybe Corel.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 3 years ago by Wilt. (2 edits in all) | Oct 08, 2020 19:35 | #2 What brand of camera? If Canon, DPP RAW conversion software is usually included with the camera. The RAW convertors found in Elements and PaintShop Pro are typically not as robust as the RAW conversion of Photoshop, Lightroom, or Capture One. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
vision35 THREAD STARTER Senior Member More info Post edited over 3 years ago by vision35. (5 edits in all) | Its Canon and for some reason it doesn't like Windows 10 Pro. Typo earlier: The installed software is DPP 4.12.70 opens then shuts down a few seconds later. I tried both the included CD and software from Canon and unzipped it for installation.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Oct 08, 2020 21:46 | #4 The issue with Windows 10 Pro has some history behind it. "I always used DPP 4.11 without problem, but few days ago windows10 did some updates by itself and as result, now any time i try to start DPP, i get an error message "Runtime error" : " this application has requested the runtime to terminate it in an unusual way- microsoft visual C++ runtime library". Another user adds... "I'm having the same problem as well when starting the DPP4, I get "Runtime Error! This application has requested runtime to terminate in an unusual way." I've tried reinstalling DPP4, booting in Safe Mode, update display drivers, deleting all the old Microsoft Visual C++ that didn't have "Repair" option and did the "Repair" for the ones that allowed me the repair option. I still get the same error." Then someone else contributes "I contacted Canon tech support and here's what I got, "Canon is currently aware of the run time error with DPP 4 and Windows 10. The issue occurred when Microsoft updated their .Net Framework and Canon is working with Microsoft to come up with a resolution to the issue however at this time I do not have an ETA of when this issue will be resolved"."... My biggest frustration at this time is, the same DPP4 v4.11.0 works just fine in two of my laptops running Windows 10 pro with the same latest OS updates, Canon go figure." So it is obviously NOT you or your PC. "I discovered a few things that may benefit some of us here. Immediately after a startup crash, deleting the Canon_Inc_IC folder in C:\ProgramData\ resolved the startup crash, not necessary to uninstall and reinstall DPP 4. Occasionally you may have to kill 'Digital Photo Professional 4' using the Windows Task Manager after a startup crash to ensure DPP 4 is not running in the background and then delete the aforementioned folder. And someone else tried it... "I deleted the Canon_Inc_IC folder and now the version 4.11.0.2 loads up well. First problem solved. Good luck with this. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
PerfectlyFrank I'm too sexy for my lens More info Post edited over 3 years ago by Perfectly Frank. | Oct 09, 2020 01:36 | #5 vision35 wrote in post #19136010 Its Canon and for some reason it doesn't like Windows 10 Pro. The software DPP 4.1.0 opens then shuts down a few seconds later. I tried both the CD and software from Canon and unzipped it for installation. Try the latest version of DPP, which is 4.12.70 and see what happens. When you see my camera gear you'll think I'm a pro.
vision35 THREAD STARTER Senior Member More info Post edited over 3 years ago by vision35. (5 edits in all) | Digital photo professional still not working even the newest version. Weird even did a command prompt system file scan and nothing wrong. Windows version 10.0.18363.1082 Its Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz, 3601 Mhz, 4 Core(s), 8 Logical Processor(s) has 16GB memory, 5 months ago upgraded to a brand new 4TB WD hard drive 7200 RPM. I could try adding a video card with memory I doubt thats the whole problem.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 3 years ago by Wilt. | Did you try deleting the Canon directory, as suggested in another thread on another forum, before loading the new version of DPP? You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
vision35 THREAD STARTER Senior Member More info Post edited over 3 years ago by vision35. (3 edits in all) | No I did try that and didn't appear to work for me. I hope the 2 software manufacturers figure it out and if they do let customers know.
nordlysBW Senior Member More info Post edited over 3 years ago by nordlysBW. | Oct 10, 2020 11:24 | #9 Running DPP 4.12.60.0 on Win 10 pro, version 2004 (build 19041.508). Works fine so far. I suppose you restarted the computer after uninstalling DPP. Might give mix-ups otherwise, from what some people say.
vision35 THREAD STARTER Senior Member More info Post edited over 3 years ago by vision35. (2 edits in all) | The only difference I can think of is.. I used a builders OEM operating system CD vs retail Win10 Pro. I pulled all of the Canon software minus the printer software. Fully powered down the computer and full re-booted then try installed from the Canon CD instead of un-zipping stuff. Wow. That's just disappointing and strange that the DPP4 screen opens for 5-10 seconds then poof. I guess I'll be stuck paying and using different software until I email technicians or support. I'll try installing a video card with its own memory next.
DanMarchant Do people actually believe in the Title Fairy? 5,635 posts Gallery: 19 photos Likes: 2058 Joined Oct 2011 Location: Where I'm from is unimportant, it's where I'm going that counts. More info | Oct 11, 2020 00:08 | #11 vision35 wrote in post #19135713 Was looking at Elements and maybe Corel. Just FYI Elements is not a proper RAW editor (or at least wasn't when I last used it some years ago). Dan Marchant
True very true. Its called elements for a reason for sure.
nordlysBW Senior Member More info Post edited over 3 years ago by nordlysBW. | Oct 11, 2020 11:34 | #13 I would still give one workaround a try before giving up.
vision35 THREAD STARTER Senior Member More info Post edited over 3 years ago by vision35. (4 edits in all) | I have not given up yet.
JohnfromPA Cream of the Crop 11,258 posts Likes: 1527 Joined May 2003 Location: Southeast Pennsylvania More info | Oct 12, 2020 07:10 | #15 Win 10 Pro with the upgrade to 4.12.70.0 working fine. I am running an NVidia GeForce display adapter.
| Latest registered member is semonsters 1504 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
