PacAce wrote in post #19139867
I took out my EF 35mm f/1.4 L lens out for the first time in over a few years the other day and noticed that the focusing ring was gray instead of black. None of the other lenses in the same Pelican case had the same issue though. Has anybody else experienced a similar issue with the focusing ring changing color?
I've had it happen with one lens, forget which.
Basically, you haven't used it a lot. It appears that grease from hands and handling keeps the ring black
You could rub it with the tiniest bit of silicon grease (transparent variety, also used for diving equipement en rubber rings in taps). That should solve the issue. The rubber has gone dry, so to speak.
Really the tiniest pinpoint of grease should suffice. Just use a toothpick to apply the tiniest drops here and there, and rub it out evenly. Only apply to the rubber, however.
Alternatively, use it a lot over the next few weeks/months.
HTH, kind regards, Wim
