I have not been using this lens in a while. I grabbed it today, and found the main body very sticky. My fingers became black. The rubber/plastic appears to be melting away. Has anyone had this issue? Any solution found? Thanks in advance!
cfibanez Senior Member 859 posts Likes: 2 Joined Aug 2008 Location: Stockholm, Sweden More info | Nov 09, 2020 02:00 | #1 I have not been using this lens in a while. I grabbed it today, and found the main body very sticky. My fingers became black. The rubber/plastic appears to be melting away. Has anyone had this issue? Any solution found? Thanks in advance! 5D4 | 7D2 | 11-24/4.0 L | 16-35/2.8 L III | 24/1.4 L II | 24-105/4.0 L IS | 40/2.8 STM | 85/1.2 L II | 100/2.8 L macro IS | 70-200/2.8 L IS II | 100-400 L IS II | 400/4.0 DO L II | 580EXII | EF 1.4x III | Gitzo monopod GM2541 | Gitzo tripod GT2541 | Really Right Stuff ball head & plates | B+W & Singh-Ray filters
msowsun "approx 8mm" More info | I had a similar "sticky grip" problem with my EOS A2 film camera. I just used 91% isopropyl alcohol and kept rubbing and cleaning until it was all gone. The grip looks kind of shiny now, and it only feels slightly less grippy. It really doesn't feel much different than my EOS 5 and EOS 7NE, where the grip still has the original "Rubberized" surface. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
vision35 Senior Member More info Post edited over 2 years ago by vision35. (14 edits in all) | Nov 09, 2020 11:54 | #4 If the lens still works everything should be fine with a little effort and parts.
cfibanez THREAD STARTER Senior Member 859 posts Likes: 2 Joined Aug 2008 Location: Stockholm, Sweden More info | It worked! I used isopropanol (from the lab) and a cloth. Rub slowly, several times until it was all gone. Exactly as you said. Thanks very much! 5D4 | 7D2 | 11-24/4.0 L | 16-35/2.8 L III | 24/1.4 L II | 24-105/4.0 L IS | 40/2.8 STM | 85/1.2 L II | 100/2.8 L macro IS | 70-200/2.8 L IS II | 100-400 L IS II | 400/4.0 DO L II | 580EXII | EF 1.4x III | Gitzo monopod GM2541 | Gitzo tripod GT2541 | Really Right Stuff ball head & plates | B+W & Singh-Ray filters
| Latest registered member is Niagara Wedding Photographer 1320 guests, 126 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
