Thread started 09 Nov 2020 (Monday) 10:58
Old Flashes working with Digital Equipment
Xioyu
1 post
Joined Nov 2020
Nov 09, 2020 10:58 |  #1
Hi all!
This is my first post in the forum because I have a puzzle that I am not able to work out.
I bought in a market a pair of Elinchrom Studio Flashes working perfectly: 500 and Style 600. These are quite old school. No digital screen or things like that.
I have already a Godox 400, a Godox V860II-S and a Godox Trigger X1T-S. All working perfectly with my Sony A7III. I bought an original Elinchrom sincronize cable to plug into the trigger, but it doesn’t work.
Should the cell activate both flashes? Not quite sure how to make these work with my current equipment.
Any ideas?
Thanks in advance!
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2020/11/2/LQ_1072041.jpg
Image hosted by forum (1072041) © Xioyu [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2020/11/2/LQ_1072042.jpg
Image hosted by forum (1072042) © Xioyu [SHARE LINK]
Wilt
Post edited over 3 years ago by Wilt. (2 edits in all)
Nov 09, 2020 11:12 |  #2
Upper flash appears to have a photosensor trigger capability (although I cannot find a switch to enable/disable the optical trigger), while the lower flashdoes not. So you need a means to trigger the lower one via a 'connection' to your camera, and the upper flash will slave the the light from the lower flash unit.
How you trigger via the camera is 'it depends'...
  1. upon whether or not your camera has a PC port (many that are not considered 'pro grade' do not!)
  2. if no PC port, you can use a hotshoe-to-PC adapter in order to plug in a PC cord connected to the flash, or
  3. if no PC port, you can use a wireless transmitter in the hotshoe triggering via a wireless receiver at the flash
You could install a Wein optical trigger in the trigger port of the lower flash (and one for the upper flash as well) so both trigger via your Godox
ImageMaker...
looks like I picked a bad week to give up halucinagens
Gallery: 225 photos
Joined Dec 2015
Nov 09, 2020 17:35 |  #3
Wilt wrote in post #19149663 (external link)
The lower one indeed looks to have an optical sensor. Right next to its flash symbol.
Nikons, Rolleiflexes, Elinchroms, Broncolor Paras, Billinghams
Wilt
Post edited over 3 years ago by Wilt. (3 edits in all)
Nov 09, 2020 19:27 |  #4
ImageMaker... wrote in post #19149796 (external link)
My interpretation of the lower unit's control markings
  1. Lightning symbol indicates xenon Flash Tube power by slider on the Right
  2. Incandescent bulb Modelling Light power control by the slider on the Left
No apparent photosensor to receive the triggering burst of light from the master flash unit.
ImageMaker...
Gallery: 225 photos
Joined Dec 2015
Post edited over 3 years ago by ImageMaker.... (8 edits in all)
Nov 09, 2020 20:58 |  #5
Wilt wrote in post #19149834 (external link)
Take a look at the square & round thingies, top row. (Not the cable sync socket)
https://www.elinchromu​s.com …_inst_el_250_10​00--en.pdf (external link)
Reading manuals... both units will fire with their optical sensors.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2020/11/2/LQ_1072113.jpg
Image hosted by forum (1072113) © ImageMaker... [SHARE LINK]
Wilt
Nov 09, 2020 22:02 as a reply to  @ ImageMaker...'s post |  #6
I found the Elinchrom 500 user manual, and its control list mentioned
Controls
1. Mains inlet socket with spare fuse
2. Mains fuse (slow blow)
3. Illuminated mains on/off switch
4. Modelling lamp switch
5. Open flash «Test» and ready
6. Slave cell on/off
7. Stepless sliding flash variator
8. Stepless modelling lamp control
9. Synchro-socket
10.Umbrella tub
So there is indeed a control for the slave function and an idicator light, but there is not mention of a visible photosensor even in the user manual. Ergo, my error in assuming no slave function.
ImageMaker...
Gallery: 225 photos
Joined Dec 2015
Nov 09, 2020 22:36 |  #7
Wilt wrote in post #19149877 (external link)
Controls
9. Synchro-socket
10.Umbrella tub
Oddly enough, the sensor is the switch. Some kind of recursion at work...
sincity
Joined Nov 2014
Nov 15, 2020 08:40 |  #8
either strobes can use the 3.5mm to EL adapter to use whatever receiver you have to use with the Godox.
LINK to the adapter on BH~~ https://www.bhphotovid​eo.com …Ni4QNfa7Z8wEaAo​9UEALw_wcB (external link)
ImageMaker...
Gallery: 225 photos
Joined Dec 2015
Nov 15, 2020 13:16 |  #9
sincity wrote in post #19152354 (external link)
Wein has some pretty good optical sensors too.
When I have a strobe positioned such that the strobe’s optical sensor cannot see and trigger, I’ll usually place a piece of white paper near it to reflect a bit of light onto the sensor.
sincity
Joined Nov 2014
Nov 16, 2020 16:02 as a reply to  @ ImageMaker...'s post |  #10
Yeah.. I was thinking since he has the godox ecosystem.. He can get one or two receivers and the adapters... This way it is just one xmtr to control it.
1,058 views & 1 like for this thread, 4 members have posted to it and it is followed by 3 members.
1338 guests, 147 members online
