FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 12 Nov 2020 (Thursday) 10:03
Re-Mill Sigma Lens Foot to fit Arca Swiss ???
BuckSkin
Joined Nov 2014
Nov 12, 2020 10:03 |  #1
I have the last generation Sigma 50-500mm lens.
I have been on a pilgrimage to convert everything around here to Arca-Swiss.
I got the brilliant idea that maybe I could cut the tripod foot on my 50-500mm to fit Arca-Swiss without the need for a separate plate; then, as I was mulling this over in my head, I thought, if I had came up with the idea, then most likely Sigma had already beaten me to it and my lens foot may very well already be cut to fit.
I got the camera/lens and an Arca-Swiss clamp that was laying on the desk and made a quick investigation.
What I found is that the foot is definitely cut in a male dovetail configuration; however, it most definitely is NOT Arca-Swiss.
I was able to spread the clamp I had far enough apart to capture the lens foot, but just barely; and, when I tightened the clamp, the clamping bar cocked over as far as the tongue-in-groove would allow.
The lens foot was tightly clamped and probably would have held firm in most situations; however, it didn't take an Einstein to see that the fit was way off and the angle of the dovetails did not match.
Also, most likely there are Arca-Swiss clamps that are not going to open as wide as the example I was using.
I don't have an example to try; but, I sort of believe that the lens foot is cut to fit the wider, steeper angled, Bogen/Manfrotto style.
Interestingly, once I investigated this, I started reading the reviews on this lens; and, in many reviews, contrary to my own findings, the reviewer makes a claim that the lens foot is Arca-Swiss compatible; whereas, the one I have is most definitely NOT; too wide and wrong angle.
When I laid a proper Arca-Swiss plate against the bottom surface of the lens foot, the foot was quite a bit wider.
That leads me to my question: Have any of you modified your lens foot, of any make/model, to fit Arca-Swiss ?
I do have the technology to do this and I can get it done; however, if anyone else has already accomplished this conversion/re-milling, I would like to have your input on the situation.
rgfrison
Gallery: 180 photos
Nov 25, 2020 01:45 |  #2
From what I am getting the stock dovetail is probably too deep to clean up completely if you milled it to arca swiss width. Without measuring it I don't know for sure. A pic with arca swiss plate attached to foot would help.
Randy
John ­ from ­ PA
Joined May 2003
Nov 25, 2020 07:53 |  #3
Isn’t this what you need... https://www.amazon.com …mm-F4-5-5-6/dp/B07BBPLHRC (external link)
BuckSkin
Joined Nov 2014
Nov 25, 2020 14:07 |  #4
rgfrison wrote in post #19157208 (external link)
The Sigma foot is hard to get an accurate width measurement, as the bottom edges are somewhat rounded instead of coming to a nice point.
For the temporary time being, I have drilled/tapped two extra 1/4x20 holes and attached a 100mm long Arca-Swiss plate, now with three mount screws instead of the one.
John from PA wrote in post #19157317 (external link)
That is a good find.
I wish they provided more pictures and measurements.
I will keep that in mind as a back-up plan for when I make a mess out of my original while milling the dovetail.
I would not expect to have a huge market for those, as I cannot imagine anyone breaking or losing the one that is supplied with the lens.
John ­ from ­ PA
Joined May 2003
Post edited over 2 years ago by John from PA.
Nov 25, 2020 14:51 |  #5
BuckSkin wrote in post #19157470 (external link)
Check the pictures at https://www.aliexpress​.com/item/32998315937.​html (external link)
Scroll down once at the site.
BuckSkin
Joined Nov 2014
Nov 25, 2020 17:07 |  #6
John from PA wrote in post #19157488 (external link)
Thanks; the pictures help a lot.
As best I can tell, there are two recessed screws that hold the Arca-Swiss plate to the ring and the two are separate parts.
If that be the case, a smart man like me could fabricate all manner of possibilities with a set-up like that.
John ­ from ­ PA
Joined May 2003
Nov 25, 2020 18:41 |  #7
BuckSkin wrote in post #19157540 (external link)
If you look carefully, the plate is not included. Quoting from just above where the photos start
Package Including:
1 x iShoot Lens Collar Support Tripod Mount Ring IS-SM1550
(The other items in the photos not listed here are for illustrating only, not included)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Nov 25, 2020 20:56 |  #8
If the one that John linked to in post 3 was not available, I could see myself trying. If you've got access to a mill, I'm not even sure why your asking! :)
But yeah, I'd grab the one on E-Bay.
Us canon big white shooters have been replacing the included Canon foot with an Arca compatible one from Kirk, 4th Generation, RRS etc for decades.
CDS' HOT LINKS
Windsun33
Joined Mar 2012
Nov 28, 2020 21:46 as a reply to  @ CyberDyneSystems's post |  #9
See here http://www.hejnarphoto​store.com/category-s/192.htm (external link)
He makes all kinds of hard to find plates and adaptors.
My first real camera was a Canon F1. That was a long time ago.
851 views & 3 likes for this thread, 5 members have posted to it and it is followed by 3 members.
1092 guests, 117 members online
