Thread started 22 Dec 2020 (Tuesday) 17:53
LCD QUESTIONS
mdaddyrabbit
Dec 22, 2020 17:53 |  #1
I have supposedly one good screen for editing and one not so good. My good screen is an IPS made by LG, my not so good screen is a TN from Dell. I have listed the model numbers and links to the specs below. I shoot tethered, the image looks so much better on the cheaper screen, image quality, color, and brightness than the better IPS screen made by LG. Color, clarity and brightness beat the IPS screen all day. I want to be as accurate as possible with my images. Could anyone maybe explain why out of the screens I have, the cheaper one is better in viewing quality than the more expensive one?
If I would invest in newer screens what would you suggest that would not break the bank that is around 25" or larger?
SCREEN 1
LG 27MP67HQ
https://www.lg.com …lg-27MP67HQ-P-led-monitor (external link)
SCREEN 2
DELL P2212HB
https://www.cnet.com …m-panel-exchange-service/ (external link)
Thank you!
Website (external link)
CANON
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Post edited over 2 years ago by CyberDyneSystems.
Dec 22, 2020 18:49 |  #2
That is odd, but I will point out that the resolution on the LG is very low for a 27: monitor,. like really low. I don't think that should have any bearing on your question though.
CDS' HOT LINKS
Wilt
Dec 22, 2020 19:27 |  #3
CyberDyneSystems wrote in post #19170619 (external link)
But, Jake, both monitors are 1920 x 1080 Resolution.
Since the same pixel count is spread across a 27" monitor vs across a 21" monitor, the eye could be perceiving the bigger pixels of the 27" IPS and interpretating that is 'not better'.
Also, OP, have you adjusted Brightness and Contrast to NOT FACTORY settings, which are set up to look good in a bright light retail store setting where so many do their monitor choice. Maybe that is biasing your appreciation of the 21" TF monitor.
mdaddyrabbit
Dec 22, 2020 20:37 as a reply to  @ Wilt's post |  #4
I did adjust the brightness to see if I could match the Dell screen, What I ended up with was a blown out screen, way to white and bright.
CANON
Wilt
Dec 22, 2020 21:34 |  #5
mdaddyrabbit wrote in post #19170659 (external link)
Just perhaps it is the DELL that is wrongly adjusted, and it should be dialed BACK to not be so contrasty and bright?!
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Dec 22, 2020 22:27 |  #6
mdaddyrabbit wrote in post #19170589 (external link)
The LG is super cheap very low quality consumer monitor, it's IPS only because LG make IPS panels, but this is about as bad and nasty as an IPS panel can get.
The Dell on the other hand is an expensive and high quality business grade monitor, it might be a TN panel, but it's about as good as TN panel can get.
But the biggest difference is the Dell has a backlight capable of producing the full sRGB colour space while the LG has very pour quality backlight and can only produce about 72% of the sRGB colour space. Basically it's rubbish.
A good replacement for the LG would be a Dell 2412, it's about as a good a monitor can get while still being affordable.
Beyond that you have to start looking at dedicated monitors for photography and design use, BenQ offer excellent value for money, or find a gaming monitor that also has a good reviews for image quality.
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
110yd
Joined Jan 2005
Post edited over 2 years ago by 110yd.
Dec 23, 2020 02:43 |  #7
SCREEN 1
LG 27MP67HQ
Color Gamut sRGB 72%
SCREEN 2
DELL P2212HB
gamut of 82%
with a footnote that reads "Color gamut (typical) is based on CIE1976 (84%, 82%, 82%) and CIE1931 (72%) test standards on the P2312H, P2212H and P2012Hmonitors respectively"
Another relevant point would be to calibrate your monitor...I am NOT the color space expert, but I would shoot for a monitor with a higher color gamut, and then calibrate it. Color gamuts in terms of the relative range of color from narrowest to widest would be CIE 1976 < sRGB < AdobeRGB.
mdaddyrabbit
Post edited over 2 years ago by mdaddyrabbit.
Dec 23, 2020 08:08 as a reply to  @ Moppie's post |  #8
I'm inclined to agree with you Moppie. I am amazed at the quality of picture between the Dell and LG I am experiencing now. If I had known how crappy the LG was, I would not have purchased it.
CANON
chuckmiller
Gallery: 65 photos
Joined May 2012
Dec 23, 2020 11:36 |  #9
I believe a 27in screen needs to be 4k resolution, then add the other quality goodies like color gamut and back lighting and the image becomes amazing.
Retired from Fire/Rescue with 30 years on the job - January 2019
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Dec 23, 2020 16:04 |  #10
chuckmiller wrote in post #19170902 (external link)
It doesn't need to be any particular resolution, but traditionally the best 27in monitors have been 2560x1440 and newer ones are usually 4k.
However, a 27in at 2560x1440 has roughly the same pixels per inch as a 4k 40in TV.
1,126 views & 4 likes for this thread, 6 members have posted to it and it is followed by 4 members.
LCD QUESTIONS
1511 guests, 131 members online
