Bogino wrote in post #19174069
Going on my first visit to Ecuador later this year and will be spending 6 days in the Cuyabeno Reserve. The wildlife looks to be fabulous there. Will be spending most of my time on a small boat.
What tips/suggestions do you have for capturing good images from a slow moving boat so they don't all come out blurry? Even when we (my guide and I) are "stopped" on the river there is always going to be motion. Just wondering how to address that. I suspect that for most of my river shots of wildlife I'll be using my Canon 100-400mm which is a bit heavy.
You shouldn't have any trouble at all with the motion of the boat causing softness or blur due to camera motion. . That is a total non-issue. . Shutter speed is often overrated, and many people have errant ideas when it comes to how much shutter speed one needs in any given situation.
The real issue will be the difficulty in framing your images very precisely when shooting from a boat that bobs around. . You may have the eye of a bird perfectly placed on the upper right "power point", only to have the bobbing of the boat cut the end of the bird's tail off. . Or you may have your lens zoomed in so that a deer is placed tastefully along the right side of the frame, and a dark tree trunk is perfectly lining the left edge of the frame, but the bobbing boat causes you to shoot a little more to the right than you had intended, which results in the tree trunk being excluded from the composition.
The other related problem is that you will really struggle to keep the camera precisely level at all times, which could result in off-kilter horizon lines and out-of-perfect-plumb verticals.
Unfortunately, I think the only way to overcome this challenge is to shoot a little wider than you really want to, and then crop the images a bit later. . This will allow you to rotate the images to restore vertical and horizontal integrity, as well as preventing you from cutting off things that you wanted on the far edges of your compositions. . I love very precise in-camera framing, and hate to waste any pixels, but there are situations in which this cannot be avoided.
Here's a photo I took from my canoe back in June. . A shutter speed of 1/800th of a second was way more than fast enough ..... I am positive that I would have gotten exactly the same sharpness if I had used 1/250th of a second, or possibly even slower.
Image hosted by forum (
1080573)
© Tom Reichner [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. ."Your" and "you're" are different words with completely different meanings - please use the correct one.
