FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 08 Jan 2021 (Friday) 11:32
128GB SD/iMac
racketman
Gallery: 20 photos
Jan 08, 2021 11:32 |  #1
Seems my iMac doesn't want to know a 128GB Sandisk Extreme Pro SDXC. I use the card slot and have never had issues with 64GB or below. iMac 27" 5K, OS Big Sur.
Photos/videos wont load and card has to be forcibly ejected. I've returned to Amazon (def not a fake card) and bought another 64GB but out of interest is this a known issue with the bigger card?
Toby
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Jan 08, 2021 13:01 |  #2
racketman wrote in post #19178567 (external link)
I am curious to know ..... did you open the program "Photos" while your card reader and this card were plugged in?
I use Photos, and have never had a problem with it "seeing" and downloading anything from any of my CF cards. . But sometimes, albeit very rarely, if I am not in Photos, then my iMacs are not able to "see" a CF card when it is plugged in.
racketman
Gallery: 20 photos
Jan 09, 2021 10:59 as a reply to  @ Tom Reichner's post |  #3
No but I never used Photos before with any card either and they all opened. Today I have had the same problem with a new 64GB SD card (not CF). However by using a card reader rather than the slot in the iMac the problem is solved so maybe I could have successfully opened the 128GB too using a card reader.
The iMac's SD slot must be compromised.
Toby
John ­ from ­ PA
Joined May 2003
Jan 09, 2021 15:39 |  #4
racketman wrote in post #19179024 (external link)
See if this could be your issue.
https://cvil.ly …d-reader-fix-9893875fa106 (external link)
Archibald
You must be quackers!
Gallery: 789 photos
Post edited over 2 years ago by Archibald. (2 edits in all)
Jan 09, 2021 22:30 |  #5
The 128GB card might be formatted in exFAT, which is Microsoft proprietary. This format is used for big capacity cards so the card can be used for 4GB files. I had big problems some time ago with a 128GB card, trying to get my Android device to read it, without success. Apparently MS has not licensed the format for other operating systems. Very annoying.
When I had this issue, I remember trying to reformat the card as FAT32, but that failed and disabled the card. I had to return the card.
This was all several years ago and things might have changed, but it might be a file storage system issue.
Pippan
Gallery: 1260 photos
Joined Oct 2015
Jan 09, 2021 23:47 |  #6
Not much help but I use the same brand, type and size of card in a 2017 27" 5K iMac running Big Sur and have no issues. So it's not something inherent in the iMac or Big Sur. Sadly though my favourite raw processor, Photo Ninja, crashes with Big Sur (it ran fine until the OS upgrade).
Still waiting for the wisdom they promised would be worth getting old for.
Pippan
Joined Oct 2015
Jan 09, 2021 23:48 |  #7
Archibald wrote in post #19179259 (external link)
Although a Microsoft format, Macs can read exFAT formatted media.
Archibald
Gallery: 789 photos
Jan 10, 2021 01:18 |  #8
Pippan wrote in post #19179276 (external link)
I see. So I guess that isn't it. Thanks.
John ­ from ­ PA
Joined May 2003
Post edited over 2 years ago by John from PA.
Jan 10, 2021 09:24 |  #9
“racketman”, have you tried what I posted earlier (see reply #4)? It involves a switch involved in the detection of the card that can get dirty and then the iMac doesn’t recognize the card. The typical symptom, which you seem to have, is the card or cards is not recognized in the iMac but seem to be OK using a card reader.
See https://cvil.ly …d-reader-fix-9893875fa106 (external link)
gossamer88
"something else"
Gallery: 94 photos
Joined Aug 2014
Jan 10, 2021 10:05 |  #10
My 2013 iMac can read my 128GB Lexar SD UHS-II (external link) that I bought over the holidays.
EOS R5 | EOS R7 | iPhone 12 Pro
RF 100-500mm | RF 100-400mm | RF 800mm F11 | RF 600mm F11
RF 24-240mm | RF 50mm 1.8 | RF 35mm 1.8 Macro | RF 16mm 2.8
racketman
Gallery: 20 photos
Post edited over 2 years ago by racketman. (9 edits in all)
Jan 10, 2021 15:49 as a reply to  @ John from PA's post |  #11
Haven't tried that as I don't think the slot switch is stuck. It's all very strange. It can initially recognise the SD card (64GB 170mb/s, no longer have the 128GB) but I cant open the files in Photoshop whether jpeg or RAW and whether shot in Olympus or Panasonic body and then they disappear (actually still there when opened with card reader) and the disk has to be forcibly ejected.
No problem with same card when read from card reader.
A slower 95mb/sec 32GB works fine from the slot as does a 32GB 300mb/s so can't be the stuck switch.
All cards are exFAT.
Anyway I'm happy using a card reader, just intrigued now.
P.S seems to be the same problem W Johnson has in this thread, 22nd post down:
https://www.fuji-x-forum.com …a-in-macos-1015-catalina/ (external link)
the post after suggests its a problem when you combine an old internal or external card reader with a new OS and a new SD card !! Evidently my Integral 5 in 1 USB 2.0 card reader is new enough to match Big Sur and a brand new SD card but my late 2014 iMac 5K internal SD slot is too old :lol:
IMAGE: https://live.staticflickr.com/65535/50821978338_8e59a95482_h.jpg
IMAGE LINK: https://flic.kr/p/2kqX​VxQ  (external link) Screenshot 2021-01-10 at 22.19.04 (external link) by tobyjug5 (external link), on Flickr
Toby
racketman
Gallery: 20 photos
Jan 10, 2021 16:17 as a reply to  @ gossamer88's post |  #12
So you must be using an old OS or a new OS and a new card external reader (see above)
Toby
John ­ from ­ PA
Joined May 2003
Post edited over 2 years ago by John from PA. (3 edits in all)
Jan 10, 2021 16:33 |  #13
racketman wrote in post #19179569 (external link)
So, you have multiple cards that can’t be read from the iMac slot, but can be read from a reader. What makes you think the switch isn’t stuck. Have you opened the link I provided and read the procedure, which takes only a few minutes?
gossamer88
"something else"
Gallery: 94 photos
Joined Aug 2014
Jan 10, 2021 17:08 |  #14
racketman wrote in post #19179592 (external link)
I'm using the built-in card reader and running macOS Mojave.
racketman
Gallery: 20 photos
Jan 11, 2021 04:05 as a reply to  @ John from PA's post |  #15
No only two brand new cards, the older cards are fine.
Toby
1,711 views & 1 like for this thread, 6 members have posted to it and it is followed by 5 members.
128GB SD/iMac
1504 guests, 130 members online
