The 7D menu is different from the choices found in my 7DMkII menu; I cannot find a definitive answer in my David Busch 7D book.
I decoupled the focus function from the shutter button.
I left the default setting for the AF-ON button and did not change the default "manually selected AF point" in INFO.
What I wanted to achieve, like I have done with the 7DMkII, was to set the *(Star) button to also be an AF-ON button, but to also automatically use all focus points.
I am beginning to fear that this is not possible with the 7D.
1. - In INFO, can someone please explain the outcome of selecting "registered AF point" as opposed to the default setting "manually selected AF point" ?
2. - How do I register an AF point ? I think I got this figured out.
3. - Can I register all of the AF points to achieve what I was hoping for, which is the *(Star) button automatically using all AF points, whereas the AF-ON button only uses the manually selected point(s) ?
>>>EDIT>Update: On page 219 of the user manual, " <AF> Switch to Registered AF Function "
I have read, reread, and read again, and it is still not sinking in.
Is this meaning that I can set up a particular AF scenario and call it up by simply pressing the *Star button, and achieve that which I described above ?
Thanks for reading and all help is appreciated.
