Thread started 22 Jan 2021 (Friday) 11:33
corrections for sharpening and noise reduction
bradman11
Gallery: 6 photos
Joined Jan 2005
Jan 22, 2021 11:33 |  #1
picture is for reference: question is no matter what settings I use in camera, I have to make post processing corrections for sharpening and noise reduction. On every image wich could be in the hundreds. Any help for in camera settings that would help correct this.
In HS Gym with ok lighting for a gym
EDIT METADATA ADD TO GALLERY Canon EOS
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2021/01/4/LQ_1084101.jpg
Image hosted by forum (1084101) © bradman11 [SHARE LINK]
Canon 1D X ii, EOS R5, EF 24-70 2.8, EF 70-200 2.8, EF 100-400, RF 28-70 2.0
sogs
Gallery: 648 photos
Jan 22, 2021 17:04 |  #2
bradman11 wrote in post #19184717 (external link)
Hosted photo: posted by bradman11 in
./showthread.php?p=191​84717&i=i110475490
forum: Sports
Your ISO is 6400. You can try lowering your shutter speed based on the focal length you are using (not sure if this is enough to stop action in sports) and see how much it improves. I use 125 for concerts (I'm close enough to use a short focal length) which has poor lighting and it stops action just fine. My ISO varies though and is still usually high enough to create noise (I use auto ISO). I still have to use noise reduction software (Topaz Denoise). I don't think you can get the ISO low enough with a shutter speed fast enough to stop action with indoor lighting. Maybe someone has a different suggestion.
Time waits for no one!
Brattina1221
Gallery: 85 photos
Joined Mar 2018
Jan 23, 2021 07:28 as a reply to  @ sogs's post |  #3
I think the heavenly mix of ISO/aperture is definitely part of it - High ISO and the 2.8 can't be helping. I would be curious where your focus point shows on this photo, once you're down near 2.8 you will be cancelling out a lot of your frame from a clarity aspect
www.blakebrattina.com (external link)
http://www.instagram.c​om/blakebrattinaphoto (external link)
bradman11
Gallery: 6 photos
Joined Jan 2005
Jan 23, 2021 09:32 as a reply to  @ Brattina1221's post |  #4
I use single spot focus and try to always keep it on the players face. Obviously as they move it can be a struggle to keep up.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 2 years ago by TeamSpeed. (2 edits in all)
Jan 23, 2021 14:15 |  #5
Be sure to set a custom white balance, if that is off your noise will appear more prevalent. Also push your exposure a bit hot and you can bring down the exposure later with better results. Obviously don’t blow out highlights and this may mean shooting at 12800 to get the exposure to the right and still get a shutter speed that stops the action.
At that ISO, you will likely need to do NR. I build a custom post processing action made of several steps/filters and run an entire folder through in bulk after a game. I just run off and make a coffee and get a snack while it runs then I only for composition after.
I use spot AF on my 5d4 for pro basketball players with great success, so I think you are pretty close to having this process nailed down.
chuckmiller
Gallery: 65 photos
Joined May 2012
Post edited over 2 years ago by chuckmiller.
Jan 23, 2021 15:44 |  #6
Can you stop that action with a 500/sec? If so could you then use ISO 3200? Is that sensor clean at 3200? If no to all of this then follow Teamspeed with ISO 12,800 but that is going to make even more noise you'll have to clean up. You shot that photo at 70mm. Maybe you could try a 50mm 1.2 or 1.4 or 1.8 to get that ISO to a cleaner number.
Retired from Fire/Rescue with 30 years on the job - January 2019
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Jan 23, 2021 16:02 |  #7
I shoot at 1/1600th or faster when at all possible, and I will go to 25600 on the 5D4 from time to time to make that happen along with exposing to the right. I shoot JPG from the 5D4 after setting up WB, High ISO NR, and a picture style that fits my post processing, then just run the JPG through an action in bulk.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2021/01/4/LQ_1084347.jpg
Image hosted by forum (1084347) © TeamSpeed [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2021/01/4/LQ_1084348.jpg
Image hosted by forum (1084348) © TeamSpeed [SHARE LINK]
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Jan 23, 2021 16:14 |  #8
I would shoot the 7D2 as well and really push it to the limits. I tried to keep that under 12800 if possible, but the same principles applied. This was at ISO 10000, regardless of the POTN exif data.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2021/01/4/LQ_1084351.jpg
Image hosted by forum (1084351) © TeamSpeed [SHARE LINK]
HKGuns
Gallery: 45 photos
Jan 24, 2021 08:16 |  #9
I haven't used the DX2, but will assume, like the DX3, that ISO 6400 is just fine for your purpose, contrary to what others are posting.
While you didn't ask for a critique, I feel like it is the only way to help you out.
- You have a 200mm lens and are shooting it at only 70mm?
- Crop tighter, the bleachers aren't the subject, zooming in would be better because at 2.8 you'll obliterate the background
- Shoot RAW if you are not or at least RAW + JPG
- Shooting the picture is only 1/4 of the job, post processing is a necessity, just like developing was back in the day
- There may be motion blur in the photo you posted, try 1/1600 shutter
- Based on that histogram, expose more to the right and bring the exposure down in post
Bottom line is that I bet no-body here shoots prize winning shots straight out of the camera. If you don't want to post process, you're going to spend a lot of money searching for something you won't find.
bradman11
Gallery: 6 photos
Joined Jan 2005
Post edited over 2 years ago by bradman11.
Jan 24, 2021 11:30 as a reply to  @ TeamSpeed's post |  #10
Thanks for that info. I do use custom white balance using a white balance card.
bradman11
Gallery: 6 photos
Joined Jan 2005
Jan 24, 2021 11:32 as a reply to  @ chuckmiller's post |  #11
I used an 85at 1.8 Friday and like the results but it was a different gym. I also noticed you can change the settings in the camera for a sharper image but haven’t tried this yet
bradman11
Gallery: 6 photos
Joined Jan 2005
Jan 24, 2021 11:38 as a reply to  @ HKGuns's post |  #12
Thanks for the comments. I was trying to get the 2 players in white in the image but obviously tightening the crop or zooming would’ve helped.
bradman11
Gallery: 6 photos
Joined Jan 2005
Jan 24, 2021 11:40 |  #13
Here are some from Friday night. Feel free to critique. Working 2-3 games a week to try and get better.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2021/01/4/LQ_1084496.jpg
Image hosted by forum (1084496) © bradman11 [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2021/01/4/LQ_1084497.jpg
Image hosted by forum (1084497) © bradman11 [SHARE LINK]
duckster
Gallery: 466 photos
Joined May 2017
Jan 24, 2021 11:50 |  #14
Your shot from the girls game shows f4 but you have a f1.8 lens. I would suggest that you use the fast lens at a much wider aperture to bring down the ISO. I am just a hobbyist but that is how I would do it.
bradman11
Gallery: 6 photos
Joined Jan 2005
Jan 24, 2021 11:53 as a reply to  @ duckster's post |  #15
Thanks I was trying several settings to try and hone in the best settings. These are just pictures of my family.
2,943 views & 17 likes for this thread, 8 members have posted to it and it is followed by 7 members.
1299 guests, 123 members online
