Thread started 08 Feb 2021 (Monday) 11:09
Unable to open Sony A7II raw (arw) on Lightroom 5.7
randalcandari
Feb 08, 2021 11:09 |  #1
I apologise in advance f this has been posted before.
I just got a sony A7ii last week (was going to get an eos RP but got a really good deal on the sony) and i’m still learning the new system.
I’m getting an error when i try to open the sony raw files on Lightroom 5.7. The lightroom support sheet says a7 ii is supported and i think i have the correct version of both the sony and lightroom software.
I know upgrading to to adobe cc would fix my issue but i dont want to go with the subscription approach yet unless that would be the only option.
Anyone have any any ideas to get this to work? For now im converting to dng to get it to edit on LR.
Randal
A camera and a lens
Bob_A
Gallery: 48 photos
Joined Jan 2005
Feb 08, 2021 12:57 |  #2
InPhoto wrote in post #19175820 (external link)
Great! We will need more from this gorgeous lady!!
randalcandari wrote in post #19192615 (external link)
LR 5.7.1 (not 5.7) and ACR 8.7.1 are the minimum versions required to support the Sony A7II. I suspect the x.x.1 update added support for the camera. :)
Bob
randalcandari
Feb 08, 2021 17:15 as a reply to  @ Bob_A's post |  #3
This is what I see on the "About Lighroom" page. Sorry the version numbers are too small but it says Version 5.7.1 and Camera Raw 8.7.1.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2021/02/2/LQ_1087116.jpg
Image hosted by forum (1087116) © randalcandari [SHARE LINK]
Randal
A camera and a lens
Bob_A
Gallery: 48 photos
Joined Jan 2005
Feb 08, 2021 22:36 as a reply to  @ randalcandari's post |  #4
Pretty bizarre as the Adobe site says the A7II is supported. The A7RII on the other hand is not supported.
Bob
randalcandari
Feb 09, 2021 04:12 as a reply to  @ Bob_A's post |  #5
Yep, might probably look for alternatives. I'm checking Luminar as it seems a lot of people are liking it.
Randal
A camera and a lens
Bob_A
Gallery: 48 photos
Joined Jan 2005
Feb 09, 2021 22:08 as a reply to  @ randalcandari's post |  #6
I like the new "Photography Plan" subscription model that Adobe has as it costs about the same (maybe just a bit less) as when I was upgrading LR every version and PS every second version (was $208.95 US for PS and $82.95 US for LR) and the products are always up to date. Not a good deal though for anyone that uses a piece of software until it dies.
If I didn't use PS I would have contemplated going with an LR alternative. Too bad Adobe doesn't have a LR only option without the 1TB cloud storage. :)
Bob
randalcandari
Feb 10, 2021 03:05 as a reply to  @ Bob_A's post |  #7
Yup, have looked at Adobe's subscription plans. I'm thinking about the LR +1TB plan. it's about $10 USD per month here so not too bad. Just need to make sure Adobe will allow me to temporarily suspend my subscription in case my schedule gets too busy ;-)a
Randal
A camera and a lens
mwsilver
Gallery: 54 photos
Joined Oct 2011
Post edited over 2 years ago by mwsilver. (2 edits in all)
Feb 14, 2021 17:45 |  #8
randalcandari wrote in post #19193346 (external link)
If you stop your subscription you will still be able to access your images but you will not be able to edit them. I don't believe there is a process that supports temporarily suspending and restarting support. Most likely you will have to cancel and resubscribe. Cancelling and re-subscribing might even cost you more then maintaining the subscription.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Feb 14, 2021 22:41 |  #9
I should have responded to this post earlier. The LR + 1TB plan is not similar to LR 5.7 or LR6. When Adobe went subscription in 2017 it introduced a new mobile version called Lightroom (LR). This format is not as robust as LR 5 or 6 and sends your files to the cloud automatically. I have never installed it.
The version that is similar to what you are used to (LR5) is now called Lightroom Classic, LR Classic or the app icon that is named LrC. It requires local file storage with an option to sync to the cloud. If you do it only sends Smart Previews that use almost no cloud storage space at all.
I would suggest to get the 20GB Photography Plan which includes LrC, LR and PS for $10 a month. If you need 1TB of cloud storage your can get this plan for $20 a month. If you want to use the mobile version only (LR) then the 1TB plan is for you.
Just a note. The intent is to either install LrC or LR on you desktop. While people have found workarounds to use both they weren't designed to do so. Simply said both programs want to be the boss :-) It can be done but takes a bit of research. If you plan to use LrC and use it like you have with LR5 only then you only need the 20GB Photography plan for $10.
Image Editing OK
digital ­ paradise
Gallery: 157 photos
Post edited over 2 years ago by digital paradise.
Feb 14, 2021 22:59 |  #10
mwsilver wrote in post #19195458 (external link)
No you can't suspend. It is based on annual contract so there are penalties. If you contact Adobe they can be good about accommodating you in special circumstances. It's not that they care but it is about numbers like cable companies, etc. Threaten to leave and they will try and keep you. While I didn't really need it I called them during COVID last summer and the gave me a few breaks. They may honour a one time suspension for special circumstances but I doubt they would on a regular basis.
https://www.lightroomq​ueen.com …l-cc-subscription-photos/ (external link)
I just did a random search. I didn't read it. I pay for the whole year so I doubt I'd get a refund. If I didn't I wouldn't care.
https://www.adobe.com/​legal/subscription-terms.html (external link)
Image Editing OK
randalcandari
Feb 17, 2021 00:29 |  #11
digital paradise wrote in post #19195575 (external link)
Thanks for the detailed descriptions. I didn't know about the LR and LrC differences. I might go with the LrC + PS option. I've been planning to try to Luminar but the past 2 weeks have been pretty busy.
Randal
A camera and a lens
randalcandari
Feb 17, 2021 00:31 |  #12
digital paradise wrote in post #19195583 (external link)
Yeah, I confirmed this with Adobe and early cancellation is 50% of whatever is remaining of the 1 year contract.
Randal
A camera and a lens
digital ­ paradise
Gallery: 157 photos
Feb 17, 2021 07:56 |  #13
randalcandari wrote in post #19196625 (external link)
That's the photography plan and you get LR as well. You want to try/use it later.
Image Editing OK
1,184 views & 3 likes for this thread, 4 members have posted to it and it is followed by 8 members.
1506 guests, 110 members online
