I need to purchase some new ND filters for my RF 14-35 and 24-70/2.8 lenses. There's many options. I'd appreciate very much your recommendations! Thanks!
Feb 13, 2021 08:47 | #1 I need to purchase some new ND filters for my RF 14-35 and 24-70/2.8 lenses. There's many options. I'd appreciate very much your recommendations! Thanks! Flickr https://www.flickr.com/photos/downhillonwater/
EdgarinATL Senior Member More info | Feb 13, 2021 08:57 | #2 I have switched to Marumi pro grade filters available at B&H and other places. I have been very pleased with them. They are moderately priced. Canon EOS enthusiast
Canonuser123 Goldmember More info Post edited over 2 years ago by Canonuser123. | Feb 13, 2021 10:31 | #3 I liked the Breakthrough Photography ND filter I bought, real easy to grip the outer edge when you need to remove it.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Feb 13, 2021 12:14 | #4 Canonuser123 wrote in post #19194854 I liked the Breakthrough Photography ND filter I bought, real easy grip the outer edge when you need to remove it. I always used to buy only B + W before for any filter I needed but I see no problems with The Breakthrough Photography filter. Back when lens barrels were aluminum, it made a lot of sense to buy filters with brass rings...much less self'binding' of similar metals. Now that so many lens barrels are composite, the issue of self-binding is lessened, and one can more readily get by with filters with aluminum rings. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Canonuser123 Goldmember More info | Feb 13, 2021 19:35 | #5 Wilt wrote in post #19194899 Back when lens barrels were aluminum, it made a lot of sense to buy filters with brass rings...much less self'binding' of similar metals. Now that so many lens barrels are composite, the issue of self-binding is lessened, and one can more readily get by with filters with aluminum rings. I stand by what I said, the filter is designed to be real easy to remove, I use it for Air Shows and switch back and forth between on and off depending on whether I am shooting jets or prop engine planes. It is a great filter and it doesn’t seem to have any adverse effect on the picture quality. https://breakthrough.photography …nsity?variant=30850759185
| Latest registered member is semonsters 1470 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
