Thread started 12 Apr 2021 (Monday) 19:05
Photoshop and Graphics Card Issue
tspencer1
Joined Oct 2015
Apr 12, 2021 19:05 |  #1
I installed the latest version of Photoshop and upon launching got some sort of graphics card error message but the message will not pop up again so I'm not sure what it said. If I go into preferences/performanc​e - the option to check the "use graphics processor" is grayed out.
In photoshop systems info, I found this:
The GPU Sniffer crashed on 4/12/2021 at 7:53:28 PM
------- GetVideoCardInformatio​n
WARNING: No native GPUs found
SufficientVideoMemForT​extures: True.
DoesGPUSupportFeature( kGPUFeature_All ): False.
PSGLDocDrawingOSVersio​nTest: True.
IgnoreVideoMemRequirem​ents: False.
NativeGPUAvailable: False.
OpenCLGPUAvailable: False.
OpenGLGPUAvailable: False.
GetAIFSharingContext: False.
SupportsOpenGL(): False.
gPreferences.GetPhotos​hopCrashed(): False.
gpuE (disallowOpenGLWindows​): False.
Graphics card is Intel HD Graphics 530. Version 27.20.100.9316.
Guessing that my graphics card is too old? I tried updating the driver but no change.
What does checking the "use graphics processor" box do anyway?
Thanks-
Wilt
Post edited over 2 years ago by Wilt. (9 edits in all)
Apr 12, 2021 19:18 |  #2
Judging from the report, it seems that although you THINK you have a GPU, none is being detected...IOW it is not functioning and responding to interrogation about its presence.
"The HD Graphics 530 is an integrated graphics solution by Intel, launched in September 2015. Built on the 14 nm+ process, and based on the Skylake GT2 graphics processor, the device supports DirectX 12." It is not that old. Nevertheless...
  • WARNING: No native GPUs found
  • DoesGPUSupportFeature( kGPUFeature_All ): False.
  • NativeGPUAvailable: False.
  • OpenCLGPUAvailable: False.
  • OpenGLGPUAvailable: False.
"Older Intel video hardware is no longer supported" and this web page apears to explain the issue
https://community.adob​e.com …rror/td-p/11131207?page=1 (external link)
"If the manufacturer of your system or motherboard uses OEM-specific drivers for the Intel HD Graphics, that error (usually) means that the OEM-specific drivers are legacy drivers rather than DCH drivers, and that the OEM itself had not updated its OEM-specific drivers to a recent-enough version to be "supported" in Premiere Pro. That HD Graphics 630 is indicative of a 7th-Generation (Kaby Lake) CPU, which is within Premiere Pro's hardware support. And current versions of Windows 10 love to automatically revert Intel drivers back to the most recent OEM-verified version even if that driver version is obsolete, whether you want it or not. And this occurs regardless of whether or not you updated the driver to a current generic version (legacy or DCH). Generic Intel drivers, legacy or DCH, cannot be installed cleanly over OEM-specific drivers - period."
Also, your system was manufactured prior to mid-2018. So, legacy drivers were the rule for OEMs. DCH was not yet released at the time of your system's manufacture. Only newer systems that were manufactured after Fall 2018 came with DCH Intel drivers. And the newest generic Intel DCH drivers can now be installed cleanly on top of OEM-specific drivers, so long as the OEM driver itself is also DCH (not Legacy).
So although you TRIED to update your drivers, there should be the 'DCH' but "Generic Intel drivers, legacy or DCH, cannot be installed cleanly over OEM-specific drivers - period." and "legacy Intel drivers for 6th- and newer-generation CPUs have only been available via Microsoft's Windows Update service, and are no longer available directly from Intel." And the finger of blame from Adobe is at Windows, but they give some hope...
"With the forthcoming major update to Windows 10, driver updates will be moved to the "Optional updates" section of the Windows Update page in the Settings. That means that the obsolete driver will no longer be automatically downloaded or installed, although you may still do so if you wish to."
Good luck in your efforts.
tspencer1
Joined Oct 2015
Apr 12, 2021 19:45 as a reply to  @ Wilt's post |  #3
Wilt - EXCELLENT info - THANK you. I downloaded a freebie PC benchmarking program and although my older system (Acer Aspire TC-780) did so-so, the graphics card came up as in the 0th percentile. I did not even know a "0" was possible. So I am ordering a new modern graphics card. Hopefully that will solve the problem?
Wilt
Post edited over 2 years ago by Wilt. (2 edits in all)
Apr 12, 2021 22:19 |  #4
tspencer1 wrote in post #19222325 (external link)
Well, when the driver software is obsoleted by Windows 10, it does not start up properly, so the GPU is effective 'dead' since it is not running the driver software needed for Windows 10 to 'see' it.
I think it sucks that so many things were obsoleted because the manufacturers did not update their software for Wiindows 10 and Windows did nothing about any 'compatability mode'. for older druver support..both parties basically created the problem that products released in 2015 become dead-ended by Windows 10.
I have a flatbed scanner that officially has no Windows 10-compatible driver. Most folks would give up and throw away a perfectly good scanner...I was more bull headed and learned that the Windows 8 driver worked under Windows 10, so I still get to use my scanner, but officially to both Canon and to Microsoft it is a dead product! vmad
tspencer1
Joined Oct 2015
Apr 13, 2021 13:03 as a reply to  @ Wilt's post |  #5
Thanks - I assume any new card will have a driver that works with Windows 10?
Wilt
Apr 13, 2021 13:14 |  #6
tspencer1 wrote in post #19222568 (external link)
Always best to read the box and/or user guide to validate compatability with Windows 10
tspencer1
Joined Oct 2015
Apr 13, 2021 18:59 as a reply to  @ Wilt's post |  #7
Just for kicks I tried rolling back the driver from a Mar 2021 to a Feb 2021 non-DCH driver. I don't even know what DCH is. But it worked - Photoshop now recognizes the graphics card. I'm still going to get a new card to boost performance. Thanks again.
BuckSkin
Joined Nov 2014
Apr 26, 2021 09:38 |  #8
One more reason to avoid Windows 10 .....
J ­ Michael
Apr 26, 2021 22:05 |  #9
BuckSkin wrote in post #19227954 (external link)
Funny. Last week I had a similar issue on an Ubuntu system. Apparently a driver update, necessitating a rollback of that driver.
tspencer1
Joined Oct 2015
Apr 29, 2021 16:24 as a reply to  @ J Michael's post |  #10
Just to close the loop - I installed a Gigabyte GeForce GT 710 2GB Graphics Card. That did the trick. Also boosted video editing time considerably. The last video project I did was a 30 minute video that took Premiere Pro 22 minutes to render. Now with the card, took 6 minutes.
Thanks all.
968 views & 3 likes for this thread, 4 members have posted to it and it is followed by 6 members.
1061 guests, 101 members online
