I have a brand new Canon R5. I noticed a horrible back focusing with my 35mm 1.4 Mark I. lens.
I have tried to micro-adjust focusing but apparently there is no option for micro-adjust AF in the menu...
Anybody facing the same problem????
Thanks!
oharing Senior Member 564 posts Likes: 23 Joined Apr 2010 Location: Miami, FL More info | Apr 23, 2021 09:58 | #1 I have a brand new Canon R5. I noticed a horrible back focusing with my 35mm 1.4 Mark I. lens.
gjl711 Wait.. you can't unkill your own kill. 57,733 posts Likes: 4065 Joined Aug 2006 Location: Deep in the heart of Texas More info Post edited over 2 years ago by gjl711. | Apr 23, 2021 10:41 | #2 What would you micro-focus adjust in a mirrorless camera? The MFA feature is there to account for the difference between the light path to the focus sensor and the light path to the image sensor as they are different in a mirrored camera. In a mirrorless camera the focus sensor is the image sensor so there is not a different light path. Does the miss focus only happen when PD focusing is used or does it also miss using live view focus? Not sure why, but call me JJ.
MalVeauX "Looks rough and well used" More info Post edited over 2 years ago by MalVeauX. | Apr 23, 2021 11:05 | #3 |
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 2 years ago by Wilt. | Apr 23, 2021 12:20 | #4 The MFA is needed in a dSLR NOT because of any pentaprism consideration, but because there is a semisilvered portion of the reflex mirror which allows light to stike a secondary mirror attached to the back of the reflex mirror, and that secondary mirror reflects light DOWN to the AF sensor at the bottom of the body. MFA allows the user to compensate for different light path length to the AF sensor. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Archibald You must be quackers! More info Post edited over 2 years ago by Archibald. | Apr 23, 2021 12:46 | #5 oharing wrote in post #19226657 I have a brand new Canon R5. I noticed a horrible back focusing with my 35mm 1.4 Mark I. lens. I have tried to micro-adjust focusing but apparently there is no option for micro-adjust AF in the menu... ??Anybody facing the same problem???? Thanks! This might be due to focus shift as the lens stops down to the shooting aperture. In general, the focus of any lens will vary (slightly usually) with the aperture. So if you focus wide open with a fast lens like the f/1.4, then the focus will shift a bit (perhaps "horrible" to you). Maybe there is a way to have the R5 focus with the lens stopped-down. (I have the R5 but don't know the answer for now.) Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
Apr 24, 2021 08:38 | #6 Strange is that the camera does it with this lens only.
gjl711 Wait.. you can't unkill your own kill. 57,733 posts Likes: 4065 Joined Aug 2006 Location: Deep in the heart of Texas More info | Apr 24, 2021 09:11 | #7 oharing wrote in post #19227020 Strange is that the camera does it with this lens only. It could be a fault with the lens focused by PD. Does it work with LV focusing? Not sure why, but call me JJ.
Apr 24, 2021 12:07 | #8 gjl711 wrote in post #19227033 It could be a fault with the lens focused by PD. Does it work with LV focusing? Let me try!
| Latest registered member is semonsters 1039 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
