Softbox ... I see some have a white interior and some a silver interior.
Which is most common or preferred, and does it matter if it will be used indoor vs outdoors ?
May 01, 2021 11:12 | #1 Softbox ... I see some have a white interior and some a silver interior.
May 01, 2021 11:30 | #2 silver interior because it reflects more towards the front R5, RF 85 f1.2L, RF 50 f1.8, 6D, EF16-35 F4L IS, EF50 f1.4, EF 100 f2.8 L Macro IS
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | May 01, 2021 11:32 | #3 unlike umbrellas, reflective surface does not make such a difference in appearance of lighting, due to the diffusive front panel. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
ImageMaker... looks like I picked a bad week to give up halucinagens More info | May 01, 2021 13:11 | #4 Wilt wrote in post #19230215 unlike umbrellas, reflective surface does not make such a difference in appearance of lighting, due to the diffusive front panel. Silver is nice when the front (outer) diffuser is removed. Nice to have options like that IMO. Nikons, Rolleiflexes, Elinchroms, Broncolor Paras, Billinghams
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 2 years ago by Wilt. (3 edits in all) | May 01, 2021 13:15 | #5 ImageMaker... wrote in post #19230242 Silver is nice when the front (outer) diffuser is removed. Nice to have options like that IMO. Indeed. But these days so many use softboxes to house speedlights, that typically are aimed forward thru the opeing at the back of the softbox (not aimed back toward the silver surface), and the front panel is not removeable, particularly in the bargain softbox. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
May 01, 2021 15:34 | #6 I'll probably try one with a silver interior.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | May 01, 2021 23:13 | #7 lacogada wrote in post #19230297 I'll probably try one with a silver interior. I may get a mono light at some point but for now, I have 3 speed lights and a 3 mount bracket. Yongnuo setup with triggers and they work well. What I don't like is it takes 20 batteries if I setup all three. (enoloop recharge) Wondering if there is a bracket made that would allow me to use one receiver to control all 3 speed lights, like the hot shoes would be connected some way ? A consideration for the future: You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
ImageMaker... looks like I picked a bad week to give up halucinagens More info | May 01, 2021 23:28 | #8 Wilt wrote in post #19230417 A consideration for the future: If you intend to use a monolight or powerpack head inside a softbox with a halogen modelling light, there will be considerable heat buildup inside the softbox from the constant modelling light. That makes it especially advisible to have a cooling fan in the head/monolight, especially the monolight whose heat sensitive electronics are all inside the softbox trapping the heat. I loosen a bit of Velcro on the softbox above the strobe to help with circulation. Even though mine have cooling fans. It still helps keep the electronics cooler. Nikons, Rolleiflexes, Elinchroms, Broncolor Paras, Billinghams
May 02, 2021 07:36 | #9 Good points people ... thanks for the info.
Nick5 Goldmember More info | May 02, 2021 08:48 | #10 The Westcott Apollo line of soft boxes are designed to have the Speedlite shoot backwards into the Silver lining and then through the White diffusion panel, eliminating the hot spot. Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
RDKirk Adorama says I'm "packed." More info Post edited over 2 years ago by RDKirk. | May 02, 2021 09:02 | #11 Wilt wrote in post #19230417 A consideration for the future: If you intend to use a monolight or powerpack head inside a softbox with a halogen modelling light, there will be considerable heat buildup inside the softbox from the constant modelling light. That makes it especially advisible to have a cooling fan in the head/monolight, especially the monolight whose heat sensitive electronics are all inside the softbox trapping the heat. I haven't run into ligh that had a modeling lamp bright enough to be useful in a softbox that didn't have an internal fan. TANSTAAFL--The Only Unbreakable Rule in Photography
RDKirk Adorama says I'm "packed." More info | May 02, 2021 09:04 | #12 Nick5 wrote in post #19230524 The Westcott Apollo line of soft boxes are designed to have the Speedlite shoot backwards into the Silver lining and then through the White diffusion panel, eliminating the hot spot. I have used a 50-inch Apollo JS for more than a decade. I like them a lot. Very fast to set up. Nice square catchlight mimicking a window indoors. TANSTAAFL--The Only Unbreakable Rule in Photography
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 2 years ago by Wilt. (6 edits in all) | May 02, 2021 12:30 | #13 RDKirk wrote in post #19230529 I haven't run into ligh that had a modeling lamp bright enough to be useful in a softbox that didn't have an internal fan. Always exceptions can be encountered...I can tell you that I have 500 w/s Dynalite heads that do not have a fan, yet do have a 250W modelling light. The Dynalite 2000 w/s heads with same 250W modelling light do have a built in fan. I do not use the fanless heads in softboxes with modelling lights on constantly, only for intermittent use while positioning the head to initially light the subject and then turned off. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
RDKirk Adorama says I'm "packed." More info | May 02, 2021 15:57 | #14 Wilt wrote in post #19230593 Always exceptions can be encountered...I can tell you that I have 500 w/s Dynalite heads that do not have a fan, yet do have a 250W modelling light. The Dynalite 2000 w/s heads with same 250W modelling light do have a built in fan. I do not use the fanless heads in softboxes with modelling lights on constantly, only for intermittent use while positioning the head to initially light the subject and then turned off. I haven't run into Dynalite. I've heard of them, haven't actually laid eyes upon one. TANSTAAFL--The Only Unbreakable Rule in Photography
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 2 years ago by Wilt. (7 edits in all) | May 02, 2021 16:26 | #15 RDKirk wrote in post #19230665 I haven't run into Dynalite. I've heard of them, haven't actually laid eyes upon one. Aren't they out of business now? Dynalite shut down in 2020, after 50 years of being in business, filing for Chapter 7 bankruptcy. "Though (CEO Peter) Poremba blames 'the current decline in the photography market,' the reality might lie closer to “the current rise of affordable monolights” from companies like Godox/Flashpoint. The market is more crowded than ever, and DynaLite’s most successful and lucrative niche—arena sports photography—has been shrinking as the low-light capabilities of high-speed sports cameras has steadily improved." The name continues via an unrelated company based in Australia, a lighting and automation control system, and in 2009 that company was bought by Philips to become Philips-Dynalite. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
| Latest registered member is semonsters 1032 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
