Will the Sony flashes fit in a standard off camera hotshoe mount? I don't use Sony, but I've found a good price on Godox TT600s flashes. I only want it for off camera work to be triggered by an X-T2.
Thanks,
Mike
May 02, 2021 20:39 | #1 Will the Sony flashes fit in a standard off camera hotshoe mount? I don't use Sony, but I've found a good price on Godox TT600s flashes. I only want it for off camera work to be triggered by an X-T2. Gear: Fujifilm: X-S10, XF16 f1.4 R WR, XF18-55 f2.8-4 R LM OIS, XF55-200mmF3.5-4.8 R LM OIS, KamLan: 50mm f1.1, Pergear 7.5mm f2.8, 25mm,35mm,50mm F1.6 or so, Laowa 9mm f2.8, 65mm f2.8, Canon 300mm f4 L nFD, Nikon: 28mm f2.8 AiS, 50mm f2.0 Ai | URLS: Flickr
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 2 years ago by Wilt. (5 edits in all) | May 02, 2021 23:36 | #2 mikeporterinmd wrote in post #19230768 Will the Sony flashes fit in a standard off camera hotshoe mount? I don't use Sony, but I've found a good price on Godox TT600s flashes. I only want it for off camera work to be triggered by an X-T2. Thanks, Mike If you provide a specific Sony flash model, or camera model number we can tell with certainty. But Sony has been known in the past to depart from the general hotshoe convention with the adoption of the Minolta introduced iISO shoe in the Sony Alpha line. Sony acquired rights after the end of Konica Minolta's photography operations in early 2006. In about 2012 they re-adopted the standard hotshoe again in the Sony A99 camera, forcing to use an adapter to be compatible with older Minolta-style Sony hot-shoe accessories You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 2 years ago by Wilt. (3 edits in all) | May 03, 2021 13:12 | #3 In looking at Godox ads on Amazon, one can find entries like these
You know with certainty #1 is the Minolta/Sony shoe design You can assme that #2 is the Minolta/Sony shes, used with adapter for the standard shoe A99 You have to assume #3 is for 'current line of cameras' after Sony re-adopted the standard hotshoe design But this demonstrates the uncertainty created with a simple reference to 'Godox flash for Sony' in the question "Will it work with (unspecified camera)...there are 4 possible permuatations of responses, all of them valid because 'it depends...'
I'm not sure if I was clear. There is no camera I plan to mount the flash on. Just a standard ... I guess they are called cold shoe mounts? I don't really know what you call the thing you put on your light stand that holds the flash. I'm very new to off camera flash. I'll trigger the flash using the X-T2 trigger. Gear: Fujifilm: X-S10, XF16 f1.4 R WR, XF18-55 f2.8-4 R LM OIS, XF55-200mmF3.5-4.8 R LM OIS, KamLan: 50mm f1.1, Pergear 7.5mm f2.8, 25mm,35mm,50mm F1.6 or so, Laowa 9mm f2.8, 65mm f2.8, Canon 300mm f4 L nFD, Nikon: 28mm f2.8 AiS, 50mm f2.0 Ai | URLS: Flickr
I only want to mount in what I guess is a cold shoe? See my longer reply if you get a chance. -- Thanks, Mike Gear: Fujifilm: X-S10, XF16 f1.4 R WR, XF18-55 f2.8-4 R LM OIS, XF55-200mmF3.5-4.8 R LM OIS, KamLan: 50mm f1.1, Pergear 7.5mm f2.8, 25mm,35mm,50mm F1.6 or so, Laowa 9mm f2.8, 65mm f2.8, Canon 300mm f4 L nFD, Nikon: 28mm f2.8 AiS, 50mm f2.0 Ai | URLS: Flickr
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 2 years ago by Wilt. (6 edits in all) | May 03, 2021 15:54 | #6 It comes back to physical characteristics of the shoe/foot "the Multi Interface Shoe resembles a standard ISO 518 hotshoe with middle contact and frame ground and without any vendor-specific extra contacts, but additional electrical contacts are hidden under the front of the hotshoe. " Therefore, the hotshoe is mechanically compatible with any ISO 518-based equipment". You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Thanks for doing all this research. I had no idea this was a fairly tricky question. I'll just wait until I find TT600 (regular) on sale or maybe an AD200 if I decide I want to play outside. Not really worth it to save $15. Gear: Fujifilm: X-S10, XF16 f1.4 R WR, XF18-55 f2.8-4 R LM OIS, XF55-200mmF3.5-4.8 R LM OIS, KamLan: 50mm f1.1, Pergear 7.5mm f2.8, 25mm,35mm,50mm F1.6 or so, Laowa 9mm f2.8, 65mm f2.8, Canon 300mm f4 L nFD, Nikon: 28mm f2.8 AiS, 50mm f2.0 Ai | URLS: Flickr
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Yeah, photographers have been jerked around by Sony, over the past decades, leading me to be skeptical about abandoning a true photographic company for a 'consumer electronics' company that has repeatedly abandoned markets and product lines over 4 decades...and I personally experienced several of them! Sony may make some great products, but their commitment is not demonstrated strongly.
| Latest registered member is semonsters 1455 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
