herculeorama wrote in post #19232979
I don't know about PS, but Canon's DPP has a feature that shows you the focus point. If you use Canon i.e.
If you use Canon's own display of Focus Point in viewing a photo, you will realize that merely shows WHICH AF zone was used for achieving focus, but if you MOVED to reframe the subject (from dead center to far left, for example) the display AF point is NOT ON THE SUBJECT...it is the original location. At least it was that way for earlier models of Canon, and the AF display afterward...I have not repeated that same experiement with the new R serices. Someone should do that experiment:
- Focus on subject at center of frame.
- Recompose to locate subject to one side of frame and release shutter (without AF repositioning to follow the subject)
- View AF point to see if it conciides with the subject new location, or with the original point (centered)
...and publish the outcome on POTN so we know how R series and latest version software behave.
I konw the R-series now has eye focus and will follow the eye position, so at the time of exposure it would reflect the new subject location. But if eye focus was not active when we recompose, it should be understood by us what the behavior will be in that situation.
