Thread started 28 May 2021 (Friday) 22:49
Lens ER...clean contacts?
kezug
Post edited over 2 years ago by kezug.
May 28, 2021 22:49 |  #1
My stm 70 -250 lens is getting an error and only when zooming more than 200. I forget the error code but it said something about cleaning the contacts.
I inspected them and they all look good and even wiped it with a dry microfiber cloth. I also wiped my camera contacts as well.
Thing is the lens works fine except for anything anything higher than 200 zoom.
My 18 to 135mm works perfectly fine.
How do I clean the contacts?
What else could be wrong.
Camera and lens were not dropped. Lens was working minutes prior too even at 250mm
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2021/05/5/LQ_1105089.jpg
Image hosted by forum (1105089) © kezug [SHARE LINK]
Camera's: 70D, G12 | Len's: 18-135mm IS STM, 55-250mm IS STM, 50mm f/1.8 II | Photos:flickr (external link)
kezug
May 29, 2021 07:05 |  #2
More testing but if I have aperture wide open 5.6 and full zoo. At 250mm it works. If I start closing down aperture I get the error.
Choderboy
I like a long knob
Gallery: 185 photos
May 29, 2021 07:22 |  #3
Educated guess: It's your flex cable.
A common fault with EF 24-105 as well as some other lenses.
I never heard of it with 55-250 IS STM, but googling "55-250mm IS STM flex cable fault" indicates it does happen.
It's a cable inside the lens that gets worn out from use as it has to flex as you zoom.
You get 'clean contacts' error message as a broken flex cable causes the same sympton: no communication between camera and lens.
Dave
Image editing OK
kezug
Jun 09, 2021 06:46 |  #4
Choderboy wrote in post #19241632 (external link)
Thank you for this information on flex cable. I cleaned my contacts and it must be the flex cable being the issue.
It seems that at/beyond a certain zoom (almost 200) and ANY f stop greater than 5.6, I get the fault. I can zoom to any setting full open at 5.6 fine.
I will have to hunt down a replacement lens. This lens, a very cost effective lens, is very sharp and good to have in the bag.
chuckmiller
Gallery: 65 photos
Joined May 2012
Jun 09, 2021 09:02 |  #5
I was talking with a lens repair guy just last week. His first question was if the lens was a first gen, or 2nd/3rd. He said Canon no longer sells parts on 2nd/3rd gen lenses so those need to go to Canon for repair. I was inquiring to have just the front element removed so he made it clear that he would take no responsibility if the FRAGILE and THIN current ribbon cable snaps.
Retired from Fire/Rescue with 30 years on the job - January 2019
841 views & 3 likes for this thread, 3 members have posted to it.
1050 guests, 107 members online
