john crossley wrote in post #19260008
Personally I would contact Canon and send them the link to the images.
Unless someone on here has actually had the same problem, then it is all guess work.
Not really pure guessing, it is more educated in nature, since as you point out, the same sensor and process is used to record the raw. So to echo what was said before, the only difference in a still photo and live view is that the mirror box electronics are being used at the time of a still. The AF system is also different, so that could be another part of this. It is electronic in nature however, obviously, so it has to be one of these other systems not employed during live view.
In the end though, the only entity that can likely fix this is Canon, but will the expense even be worth it? It is likely out of warranty, and about any repair is $300+ not including delivery. A 600D isn't even worth that much on a used market. So it may be better to just use the 600D for video work or live view, and take those funds to put toward a newer camera.
