OhLook wrote in post #19273498
.I suspect (just speculating here) that the reason is a difference in sensitivity between the retina and a camera sensor. Even a dull sun is bright enough to exceed an eye's capacity for making distinctions.
I think this is definitely the case.
Most of us severely underexpose sunset images intentionally, in order to capture all of the color that the sky has in it and to not blow out those colors by overexposing. . So sunset images are often taken at several stops darker than the meter says they should be taken at. . And the meter more or less is trying to give us an exposure that is similar to what our eyes see. . So it is perfectly normal to intentionally try to NOT get a photo that is anything at all like what the eyes see when photographing sunsets.
The question I would be asking myself if I were photographing this sunset is not,
"Does the photo look like what I saw with my eyes?"
Rather, the question I would ask is,
"Does the photo look like the jPeg playback that I saw on the camera's rear screen when I was chimping during and after the shoot?"
