Thread started 27 Sep 2021 (Monday) 16:48
Question Regarding Sharpening
Bogino
Gallery: 45 photos
Joined Sep 2011
Post edited over 2 years ago by Bogino.
Sep 27, 2021 16:48 |  #1
I'm getting ready to edit photos from my recent trip to Costa Rica. Some of the images could use some sharpening. I use LR Classic and I also have Topaz. My question is:
Should I sharpen my image first in Topaz and then edit in LR? Or the other way around?
Also---My images are in RAW so maybe I can only edit those first in LR?
Thanks.
Canon 7D Mark II; Canon 70-300mm "L"; Canon 100mm Macro; Tamron 24-70mm; Tokina 11-16mm 2.8
paddler4
Sep 27, 2021 19:05 |  #2
Start editing raw files in a raw editor, like LR.
Sharpening normally comes last, but if you stay in LR, it actually makes no difference. Lightroom doesn't apply the your edits in the order in which you make them.
Check out my photos at http://dkoretz.smugmug​.com (external link)
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 2 years ago by TeamSpeed.
Sep 27, 2021 19:50 |  #3
Sharpening multiple times will likely end up with some ugly artifacts like halo-ing, or sparkles around edges of objects with less than stellar definition.
Just do sharpening once if you can, and pick the best place it makes sense for you in your workflow. Personally, I run 2 completely different Unsharp Mask runs, one enhances micro contrast to improve some of the detail through contrast changes, then a normal run that brings up the detail across the frame.
DesolateMirror
Gallery: 251 photos
Joined Oct 2015
Sep 28, 2021 03:56 |  #4
If you have a lot of photos you want to use the Topaz batch processing works pretty well, then import that into lightroom.
If there's only a few photos you want to use (or need sharpening/denoising) then going to lightroom first might be easier, just have to make sure you don't apply lightroom adjustments to the image until after you topaz it, like TeamSpeed said, extra processing like that can cause artifacts, etc.
904canon
Joined Dec 2012
Sep 28, 2021 06:42 |  #5
I do all of my color corrections in LR and spot sharpen in PS.
herculeorama
Gallery: 62 photos
Joined Sep 2012
Sep 29, 2021 00:06 |  #6
I use high-pass sharpening for all my photos. Add a black mask. And then use a white brush to reveal sharpening in the areas I need to look sharp. I don't use a mask if I want the entire image sharpened.
5D Mark III | Sigma 24/1.4 A | 50/1.8 | 100/2.8 Macro | 17-40/4 L | 24-105mm f/4 L IS USM | 70-200/2.8 L IS II USM | 400/5.6 L | Canon 1.4x III TC| Canon 2x III TC
jhsurti
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Oct 04, 2021 04:28 |  #7
I'd do as much editing as I could in LR first and then use Topaz.
Image Editing OK
694 views & 1 like for this thread, 7 members have posted to it and it is followed by 9 members.
1510 guests, 129 members online
