mn shutterbug wrote in post #19297154
It's the CPU that I've read is soldered in, not the ram. I'm still wondering if this SSD would improve things -
https://www.bestbuy.com …e/5900260.p?skuId=5900260
. Also, my desktop has just 4 GB of ram and works great for processing photos. Everything is instantaneous. The CPU speed on the desktop is 2.9 GHZ and I was hoping the laptop would be just as snappy. The desktop is probably about the same age. Even with just 4 GB of memory, it uses just 63% when issuing a command in my editing program on a large file.
A couple of things…
1. In spite of the price of $21 being attractive, I would not replace the orignal drive, likely 320 GB with something on the order of 120 GB.
2. I would also be inclined to suggest you get any SSD, from the manufacturer, be it Crucial, Samsung, PNY or whatever, but not Best Buy. That is because the manufacturer usually offers a “migration” package at minimal cost. The migration package provides a cable to hook up the new drive to a USB port. Included software will mirror your existing drive to the new SSD. This can take a couple of hours, especially in your case since you have USB 2.0 ports. Then you physically open the laptop case, remove the old drive, and install the new. A link I provided earlier seems to indicate it is easy to crack the case and swap drives. When you are done and satisfied everything works OK, you can get an inexpensve SATA external drive case for about $10 and use the old drive for backups.
I work in the business of computer repair and can tell you this process is virtualy near trouble free as a DIY. I did have one machine many years ago that after the migration had an inoperative printer. Simply reinstalling the driver, a 15 second deal, took care of the issue.
