I would really like to see some work done to change the titles of the existing sub-forums, so as to make them more inclusive. . I am one of those people who needs everything to fit perfectly into a category. . It causes major dissonance in my mind when I see a thread about an RF lens in a sub-forum that is entitled "Canon EF and EF-S Lenses".
Everything everywhere in the world should be correct and perfect and properly labeled and accurately categorized, and we can start by doing so here on POTN!
Pekka, I remember years ago you put a heck of a lot of time making improvements and additions to POTN. . You worked so hard to keep things up to date and proper. . Do you plan to still put in the same kind of effort, or have you moved on to spending your time on other things in your life?
If you have moved on, and don't plan to put the same level of effort and time into POTN that you used to, then is there some way that you can set things up so that someone else can make all of the changes and additions that are necessary to keep all of the gear-related content up to date? . It would be great if someone who is proficient at writing code could spend an hour or three every week to add each of the new camera and lens models to the gear database, and to keep up on renaming the sub-forums when it becomes necessary to do so.
