Thread started 08 Nov 2021 (Monday) 20:05
LR stack templating – is it possible?…
ttalbot
Joined Jul 2021
Nov 08, 2021 20:05 |  #1
Let's say I have a stack containing 3 RAW files in Lightroom. I want to apply one correction to the first RAW file in the stack, another correction to the last one and leave the second untouched. Then I want to save the stack as a DNG (HDR of sorts). That's totally doable by hand with one stack. But what if I have thousands of stacks that needs the exact same procedure repeated? Is it even possible without custom scripting?
Trenton Talbot Photography (external link)
DCBB ­ Photography
Gallery: 478 photos
Nov 21, 2021 12:50 |  #2
Scripting might be a tad difficult but I do think you could shorten the work assuming you already have the images stacked and you are applying the same adjustment to a single photo per stock.
1. Select all photo stacks (really the top of the stack)
2. Apply adjustments, then sync against all selected photos
3. move the selected images to the bottom of the stack
Repeat once for the different adjustment on the second image in the stack, and you are leaving one as is.
At that point you can combine into a HDR DNG by individual stack. I don't believe you could do this to multiple stacks at once.
John
641 views & 0 likes for this thread, 2 members have posted to it and it is followed by 6 members.
1455 guests, 129 members online
