Thread started 29 Nov 2021 (Monday) 05:01
Eye Detection and Eye Detection AF
willie45
Post edited over 1 year ago by willie45.
Nov 29, 2021 05:01 |  #1
All righty folks. Stupid question coming up. Brace yourselves!
Please can someone tell me what the difference between "Eye Detection" and "Eye Detection" with the little AF sign on it is on the R5
When I go to customise buttons I have the choice of setting a button to select either one of these.
I'm maybe having a senior moment but I'm a bit puzzled and I can't seem to find an answer in the manual.
Thank you
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Post edited over 1 year ago by digital paradise.
Nov 29, 2021 08:57 |  #2
This is what I understand you are trying to sort out. There are two ways to control Eye Detection. Going into the customize buttons menus or selecting the AF method on the LCD. There is an Eye Detection icon in the bottom left corner.
If so they both do the same thing. It just gives you more programming options. I use Fv and C1 -3. In one mode I'm set up so it looks for an eye before I press any buttons and just continues in Eye detect when I press the AF-on button.
Image Editing OK
apersson850
Obviously it's a good thing
Gallery: 35 photos
Nov 29, 2021 09:23 |  #3
Then comes the R3, which implements detecting the photographer's eye, to see at which subject's eye he is looking, in order to focus on that!
Anders
digital ­ paradise
Gallery: 157 photos
Nov 29, 2021 10:36 |  #4
No wonder at another site I was having some difficulty understanding why someone with thick glasses had a concern. Isn't that what diopter is for. Now that makes sense.
Image Editing OK
digital ­ paradise
Gallery: 157 photos
Nov 29, 2021 11:40 |  #5
For a little more info Willie there are so many programming options to choose from or you can use just one method that works for you. To take full advantage of this system often getting AF to hone in on your subject before switching to eye detect can help a lot. Some people are using the shutter button with single point AF just too focus in on the subject and then pressing the AF-On button with Eye detect enabled. This finds an eye much faster.
Currently I'm using that in one of my mode set ups. But the * button is programmed for Zone AF for all the modes just to get the system to quickly find the subject first. The R5 is not it the same league as the R3 but here is a good example. Notice with the R3 how he uses the single point with expansion mode to focus on the subject first.
https://www.youtube.co​m/watch?v=LGrEWOZYgDw&​t=2s (external link)
By the way, in a few days the R5 and 6 will have firmware updates to make AF more sticky.
Image Editing OK
Archibald
You must be quackers!
Gallery: 789 photos
Nov 29, 2021 15:50 |  #6
digital paradise wrote in post #19312673 (external link)
What? Do we want sticky AF??
willie45
Nov 29, 2021 16:36 |  #7
Thank you @digital paradise and others.
I wanted to do as you say and program the AF -On button for Eye AF so I went to custom functions and the button settings and under this button there are two options as in the image:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2021/11/5/LQ_1133823.jpg
Image hosted by forum (1133823) © willie45 [SHARE LINK]
1.Simply Eye Detection
2.Eye Detection with an AF sign.
On further investigation, as far as I can make out, if I set it to number 1 and the camera is in Face tracking AF mode it will simply switch ED on and off and then I have to press the focus button
- eg using the shutter button. In any AF mode other than Face tracking it will do nothing
If I set it to number 2 it will actually focus the camera using ED in any AF mode.
I can't see any other functions. Have I got this right?
willie45
Nov 29, 2021 17:08 as a reply to  @ digital paradise's post |  #8
[/QUOTE]
Hi. Just re-reading this I initially wondered why it the shutter button in the above scenario didn't override the Eye Detect with the shutter button's single point AF. I assume it does but that it is simply that the Eye detect does the job of placing the single point on the eye and it stays there when the shutter button is pressed. Is this right?
How would this work the other way round? I mean, if I had the shutter button set for Eye Detect AF and used the back button for Spot Af so that in difficult situations ( eg birds in a flock where ED on its own picked the wrong one ) I could use back button to spot focus on the bird I wanted ( ie just to help focus to get where I want it ) and then use the shutter button to hone in on the eye, would this work?
I ask because I'd prefer to use the shutter button mainly due to a thumb issue but on the odd occasion use the back button in the way I describe.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Nov 29, 2021 19:21 |  #9
My AF ON set up is simply having single point AF set up, and it is designed to be Eye AF. So I place that point on someone's face, and then it follows the eyes around the scene for me. Works very well, and when it doesn't, I have * set up to be just spot AF with no Eye AF engaged.
digital ­ paradise
Gallery: 157 photos
Nov 29, 2021 21:33 |  #10
Archibald wrote in post #19312762 (external link)
Image Editing OK
apersson850
Gallery: 35 photos
Nov 30, 2021 02:42 |  #11
The next option will be Slippery AF...
Anders
digital ­ paradise
Gallery: 157 photos
Nov 30, 2021 09:07 |  #12
Canon has been accused of being slippery a few times.
Image Editing OK
apersson850
Gallery: 35 photos
Dec 01, 2021 02:09 |  #13
Yes, but now they'll make it a feature!
Anders
curiousgeorge
Gallery: 13 photos
Joined Feb 2006
Feb 02, 2023 12:28 |  #14
This puzzled me too, and after some playing around I've found out the simple ED is a toggle, and that it only seems to work when :-)+Tracking is enabled. So you can switch the :-)+Tracking to Eye+Tracking.
I have a custom function set for wildlife, and for this it make sense to always use Eye+Tracking. I'm not sure I'll need to ever need to quickly switch between eye and face, so I won't need ED programmed to any button.
Photos from my travels (external link)
Canon EOS R6 MkII | Canon EF 24-70mm f/4L | Canon RF 100-500mm f/4.5-7.1L | Samyang 14mm f/2.8
curiousgeorge
Gallery: 13 photos
Joined Feb 2006
Feb 02, 2023 12:32 as a reply to  @ willie45's post |  #15
I think when you press the shutter the focus may override what it was previously locked onto, which is why many people recommend using the shutter for metering only.
3,687 views & 4 likes for this thread, 9 members have posted to it and it is followed by 9 members.
1457 guests, 129 members online
