Thread started 30 Nov 2021 (Tuesday) 22:43
Bridge CS6 Export panel
D ­ Thompson
Nov 30, 2021 22:43 |  #1
The Export panel in Bridge CS6 quit loading in 2017 due to a date issue and Adobe issued a fix involving 4 zxp files. The panel has once again quit loading and again it is a date issue. I can change my system date to 11-08-2021 and it will load fine. Set date to 11-09-2021 or after and it doesn't. There is a thread in the Adobe Bridge forums and others are having the same problem. I contacted Adobe thru chat and was basically told I was out of luck since CS6 is no longer supported. I can understand not supporting versions forever, but evidently the fix in 2017 was only for 4 years. Of course, the bigger issue to me is why would a important part of a program quit working simply because a date is passed. There should've been a permanent fix to the zxp files back in 2017. Hopefully someone from Adobe will see the thread from 2017 and that people are having the problem again and actually fix it. I guess the only other option is if someone is really good at coding can fix.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
429 views & 0 likes for this thread and it is followed by 6 members.
1131 guests, 133 members online
