Thread started 05 Jan 2022 (Wednesday) 06:13
Error 2
Frodge
Joined Nov 2012
Post edited over 1 year ago by Frodge.
Jan 05, 2022 06:13 |  #1
I was getting error 2 on a lease class 10 card. 16gb 30mb/s. Never when shooting. I noticed that my continuous count on my camera was at zero. I keep it continuous just to give me an idea what my actuations are and I always use the same card. I put it in after removing photos on my pc and for error 2. I formatted it in the camera and it seemed to work. Then I went back to the pc to change the image file number to let's say img_10000 to pick up where it left off. Put it in showed fine. Took it out to test to see if images were readable put in error 2. Put another card in and left it over night and it's fine. All of my other saved info is still in the camera settings like my name and all my saved settings. So not internal battery issue. What would cause error 2 randomly when inserting into the camera and it wiping out the file number?
I did a camera reset. I didn't have very complex settings. Could this have happened by inserting and removing the card with the camera powered on?
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Post edited over 1 year ago by joeseph.
Jan 05, 2022 19:22 |  #2
Apparently error 02 is "camera cannot access the memory card" - presumably either physically by way of contacts not contacting, or circuitboard problems, or by memory card failure (which could be intermittant)
It shouldn't matter if camera is powered on or not though, as the memory card door has a microswitch that powers the camera down when opened.
not really much a user can do apart from replace the card, and if still happening you might need to get a service tech have a look at it.
TF posting: here :-)
573 views & 1 like for this thread, 2 members have posted to it and it is followed by 2 members.
Error 2
1294 guests, 135 members online
