I picked up a small 3D printer over the holiday break and thought I'd dive into a project I was considering over the past year.
I have a No. 3A Folding Pocket Kodak Model B-4 that used to belong to my grandfather. I shot a couple of rolls of VP 122 in it back in the 70's just to try it out, but I haven't used it since. The project I took on was to convert the camera to use 120 film, and I thought I'd share my progress in case someone else is interested in doing the same thing.
Here's the camera:
Since 120 film isn't as wide as 122 I added two 21mm strips to help keep the 120 film flat:
IMAGE LINK: https://photos.smugmug.com …/_DSC3772-X2.jpg&lb=1&s=A
I then printed out my parts. One 120 take-up spool and four 122 to 120 adapters:IMAGE LINK: https://photos.smugmug.com …/_DSC3773-X2.jpg&lb=1&s=A
Here's the camera with the film loaded before putting the back back on:
IMAGE LINK: https://photos.smugmug.com …/_DSC3775-X2.jpg&lb=1&s=A
I probably didn't need to but I covered up the little red window with some electrical tape since it won't see any numbers and reduced the chance of fogging the film. I put the Dyno lable on the back cover when I was a kid
IMAGE LINK: https://photos.smugmug.com …/_DSC3776-X2.jpg&lb=1&s=A Next step is to hope for some decent light and go shoot something. These should end up kind of "panoramic" which should be interesting. Because the vertical dimension of the 122 image is so large compared to 120 I'll likely only get around 6 images (maybe less). I also bought a roll of Kodak E100, but I'm going to predict that the results will be pretty bad.
I did find a video on Youtube indicating how many turns of the film advance knob are required: 11 full turns from the start line to the first frame and 4 full turns to get to each new frame should be close.
