Thread started 11 Jan 2022 (Tuesday) 19:52
Help! Canon 100-400 has loose internal components
birder_herper
Jan 11, 2022 19:52 |  #1
I have a Canon 100-400 II that takes wonderful shots, IS works, etc, but when handled it makes a clunking sound when shaken (or, not really shaken but turned around). I thought at first it might be the IS unit, but now that I look into the lens I can see the internal components vibrating severely. Something is loose! Anyone have this problem before? Any simple fix?
goalerjones
Gallery: 387 photos
Joined May 2018
Post edited over 1 year ago by goalerjones.
Jan 11, 2022 19:54 |  #2
Make sure that the lens was actually shut down properly. Put it back on the camera and turn the camera on/off. See if this fixes the issue.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 1 year ago by TeamSpeed.
Jan 11, 2022 19:56 |  #3
Try mounting the lens, then turn off IS, then turn off the camera, then dismount the lens. Perhaps the IS system needs to be parked?
I can dig out my lens to see if it does the same thing but others might have some input too.
Edit: goaler beat me to it
birder_herper
Jan 11, 2022 20:37 |  #4
I am an idiot. I never let the IS unit shut down properly before unmounting it. I have been using IS lenses for fifteen years and never noticed this. I probably had this happen before but fixed it the next time I mounted the lens on the camera. Thank you guys...your solution worked perfectly. I love these forums!
goalerjones
Gallery: 387 photos
Joined May 2018
Jan 11, 2022 20:49 as a reply to  @ birder_herper's post |  #5
I had the same problem with this lens. It seems to be more susceptible than others I have used.
751 views & 0 likes for this thread, 3 members have posted to it.
1531 guests, 130 members online
