Thread started 05 Jun 2022 (Sunday) 03:31
Canon EF 500mm 1:4 L IS USM disassembly stripdown
tedlin01
Joined Jun 2022
Jun 05, 2022 03:31 |  #1
Hello, I am tearing down my 500mm prime lens to clean and regrease all the parts as well as cleaning the glass/lenses. So far, so good. However I am unable to figure out how to detach part C21-8471 so that I can clean the lenses YN2-1216 and YN2-1215.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2022/06/1/LQ_1162072.jpg
Image hosted by forum (1162072) © tedlin01 [SHARE LINK]
Can someone help me out? According to the parts manual it should be possible..
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2022/06/1/LQ_1162071.jpg
Image hosted by forum (1162071) © tedlin01 [SHARE LINK]
tedlin01
Joined Jun 2022
Jun 05, 2022 03:35 |  #2
Btw, here is some more images of the process. I even managed to strip down the USM motor to the bone (including bearings) and put it all back together.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2022/06/1/LQ_1162073.jpg
Image hosted by forum (1162073) © tedlin01 [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2022/06/1/LQ_1162074.jpg
Image hosted by forum (1162074) © tedlin01 [SHARE LINK]
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Jun 05, 2022 03:42 |  #3
awesome work!
can you check that part number though? my parts list shows C21-8471 is the parts catalog itself...
TF posting: here :-)
iroctd
Joined Aug 2013
Jun 05, 2022 14:32 |  #4
Did you remove the 3 XA9-1052 ?
-Feedback-
tedlin01
Joined Jun 2022
Jun 06, 2022 03:35 as a reply to  @ joeseph's post |  #5
Hi, thank you.
In lack of a better name for this section of parts I used the page reference to name it. Page 5, right side. I am trying to disconnect this section from the left section on the same page. This is where I am stuck.
tedlin01
Joined Jun 2022
Jun 06, 2022 03:49 as a reply to  @ iroctd's post |  #6
Hello,
I did remove them, but nothing started moving after that. I tried to apply some force in all directions, as well as applying both lube and then alcohol into the module that seems to connect the two sections of the lens. However nothing moved and everything is really stuck so I'm not sure if this is the way to disconnect the parts of each other or not.. Perhaps they can't be disconnected.. May be some glue somewhere that assures that it won't..
As seen in the attached pictures it looks like someone has been here before because there is some "marks" and stuff. Perhaps someone glued it really hard or bent it somehow.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2022/06/1/LQ_1162296.jpg
Image hosted by forum (1162296) © tedlin01 [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2022/06/1/LQ_1162297.jpg
Image hosted by forum (1162297) © tedlin01 [SHARE LINK]
AntonLargiader
Post edited over 1 year ago by AntonLargiader.
Jun 06, 2022 04:56 |  #7
In this photo, can you indicate where you are trying to separate it? The diagram makes it seem that the shiny black ring is YA2-3737 and it is held to the YA2-3736 section by the six roller pins XA1-1200-259 which seem to still be installed. But it's very likely that I don't understand where you are in the disassembly.
tedlin01 wrote in post #19387509 (external link)
Hosted photo: posted by tedlin01 in
./showthread.php?p=193​87509&i=i103992237
forum: Canon Lenses
Image editing and C&C always OK
Gear list plus: EF 1.4X II . TT1/TT5 . Bogen/Manfrotto 3021 w/3265 ball-mount
iroctd
Joined Aug 2013
Jun 06, 2022 07:07 as a reply to  @ tedlin01's post |  #8
Did you happen to remove the three XA1-1200-609 screws? Those look to release YA2-3737.
-Feedback-
tedlin01
Joined Jun 2022
Jun 07, 2022 05:16 as a reply to  @ AntonLargiader's post |  #9
As you said, the shiny black ring is YA2-3737 but YA2-3736 is already detached. See this image:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2022/06/1/LQ_1162492.jpg
Image hosted by forum (1162492) © tedlin01 [SHARE LINK]
The part I want to detach is YA2-3733 and/or YA2-3737. Those are seen in the previous images.
I did try to remove XA1-1200-609 from YA-3737 and the ring gets loose but it doesn't really help since it's still stuck between YA-3733 and the front part of the lens.
I did try to remove XA9-1052 but that doesn't make anything move. Even when force is applied in all directions, YA2-3737 seems very very stuck..
So question is how I am supposed to get YA-3737 off.. Is it even possible? :/ Is it glued? Is it bent? I dunno..
tedlin01
Joined Jun 2022
Jun 07, 2022 05:18 as a reply to  @ iroctd's post |  #10
Sure did and it loosens YA2-3737 but it's still stuck between the parts above/below as they seem to be connected without the help of YA-3737.
iroctd
Joined Aug 2013
Jun 07, 2022 06:51 as a reply to  @ tedlin01's post |  #11
After thinking on this, I believe the set screws are the giveaway. I have them on my old Canon FD 800mm 5.6 lens and where they are used is where the parts unscrew. I found the parts catalog pdf and on page 5 it seems to show threads on the part in question.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2022/06/1/LQ_1162500.jpg
Image hosted by forum (1162500) © iroctd [SHARE LINK]
-Feedback-
Aronis
Joined Jan 2014
Jun 12, 2022 08:56 |  #12
WOW....excellent work.
Question: Do you guys think Canon will have parts for these lenses in the future? If they stop making the EF's will you still be able to DIY repair?
I missed a chance at a used 300mm 2.8 last year and kick myself for not doing it. But was worried about ending up with a $6000 block of nothing if it failed.
Mike
1Dx, 10D 28-70 L 2.8, 70-200 L 2.8 III, 50 1.4, 28 2.8
Choderboy
I like a long knob
Gallery: 185 photos
Jun 13, 2022 01:54 |  #13
Aronis wrote in post #19390125 (external link)
Mike
I think the main factor in future repair: Common parts that fail. These parts will be used up and will also be the most likely to cause you to need repairs.
This issue can also make the less common part failures easier, as longs as the 'junked' lenses due to unavailability of common fail parts are kept.
You won't end up with a block of nothing, rather a cool doorstop.
Dave
Image editing OK
tedlin01
Joined Jun 2022
Jun 22, 2022 16:32 as a reply to  @ Choderboy's post |  #14
So a little update.. I never manages to dettach the front part of the lens from the middle part but I did manage to clean the middle lenses by patiently cleaning them with sensor swabs through the small holes used by the focusing system to move one of the lenses inside the barrel. That problem is fixes now.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2022/06/4/LQ_1164991.jpg
Image hosted by forum (1164991) © tedlin01 [SHARE LINK]
However, something else happened.. While I was cleaning this thing inside the autofocus unit that I believe is named "optical encoding ring(?)" I accidently broke it into pieces.. I tried to repair it with acrylic glue but it got messy and in the end I had to accept that I lost the case..
Scouring the internet for a replacement part led me to nothing. I can not find any mentions of any spare parts of this type for my 500mm or any lenses at all out there.. I believe that my best bet is to buy an ultrasonic motor assembly for a different lens and just take the part I need from it. I dont know if this will work though.. Can anyone help out with some guidance or hook me up with someone that might be able to help?
Oh and here is the part that I am talking about:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2022/06/4/LQ_1164992.jpg
Image hosted by forum (1164992) © tedlin01 [SHARE LINK]
iroctd
Joined Aug 2013
Jun 22, 2022 20:00 as a reply to  @ tedlin01's post |  #15
I've swapped one of those before between a 70-200 f4 usm unit and a 85 1.8 if I recall correctly. The USM assembly was the same size. The 500mm USM motor in your photos looks different than those found in the smaller lenses. Looks like it has two armatures for adjusting focus than the usual one. Best advice I can give is join this facebook group called 'Learn Camera Repair'. A lot of very knowledgeable and experienced individuals there and while they mostly work on pre-digital, when they do encounter a digital problem they certainly know their stuff. Maybe someone would know how many different sizes there are, kind of like a compatibility list.
https://www.facebook.c​om/groups/360490091319​202/ (external link)
Ebay and aliexpress.com seem to be calling them USM sensor strips or bars, a search for 'Canon Sensor strip' yields some results like this one for a 70-200 2.8 which should be a larger sensor than other lenses. But it is a gamble if it the same size as those used in super telephoto USM.
https://www.aliexpress​.com …211200001613639​9411%21sea (external link)
https://www.ebay.com …trip&LH_PrefLoc​=2&_sop=16 (external link)
Lastly, don't forget the Canon parts phone number, they do sell parts to the public.
Best of luck.
-Feedback-
3,058 views & 5 likes for this thread, 9 members have posted to it and it is followed by 5 members.
1314 guests, 135 members online
