I need to print photo in 15x21 size and matt it to a4 size paper. Any advice on how to do this? This is my first time matting a photo.
kundurovic Hatchling 3 posts Joined Jul 2022 More info | Jul 11, 2022 18:27 | #1 I need to print photo in 15x21 size and matt it to a4 size paper. Any advice on how to do this? This is my first time matting a photo.
Jul 11, 2022 21:07 | #2 I may not be understanding this:
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Jul 11, 2022 22:19 | #3
'It depends' on your software used to print. Some software allows you to state the image dimensions, and then center that image automatically in the specified paper size Other software requires that you define a border width that surrounds the image area, and print that composite on specified paper size You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
kirkt Cream of the Crop More info Post edited over 1 year ago by kirkt. (2 edits in all) | Jul 12, 2022 10:34 | #4 I made a quick line drawing to help clarify what you are describing - hopefully I interpreted your description correctly. Image hosted by forum (1168339) © kirkt [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Image hosted by forum (1168340) © kirkt [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Kirk
kundurovic THREAD STARTER Hatchling 3 posts Joined Jul 2022 More info Post edited over 1 year ago by kundurovic. | Jul 14, 2022 17:14 | #5 Thanks for helping guys. I was a bit unclear.. sorry about that. This is for school project and I have prepared 8 photos in 15x21cm size. This is how brief goes. Image hosted by forum (1168689) © kundurovic [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 1 year ago by Wilt. (5 edits in all) | Jul 14, 2022 19:54 | #6
It is quite simple. Since this is a school project, you can ignore the issue of archival quality in mounting, and just use drafting tape or masking tape ordinary adhesive tape to stick the photo and mat together and hold position of the mat on the print. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Bob_A Cream of the Crop More info | Jul 14, 2022 22:49 | #7 I'd also make the print with, say, a 65mm white border such that while the overall print size is 15cm x 21cm the image area would be 13.7cm x 19.7cm. Then cut a 13.7cm x 19.7cm hole in the A4 sized mat and follow Wilt's instructions for putting it all together. Bob
Thanks for claryfing. So the opening should be self made? would it be a problem if image is exact size as opening?
sapearl Cream of the Crop More info | Jul 15, 2022 06:24 | #9 kundurovic wrote in post #19404715 Thanks for claryfing. So the opening should be self made? would it be a problem if image is exact size as opening? It will work either way, being a matter of artistic taste. I cut my own and prefer to have an exact size opening but have done it the other way with very nice results. GEAR LIST
kirkt Cream of the Crop More info | Jul 15, 2022 09:56 | #10 LOL - looks like I was 100% incorrect! Thanks for clarification. Kirk
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 1 year ago by Wilt. (3 edits in all) | Jul 15, 2022 10:08 | #11 Mat cutters are not inexpensive...for a school project it may be less expensive to simply buy precut mats from framing shops. But for long range planning, an investment today in a mat cutter can ultimately prove to be a savings. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
sapearl Cream of the Crop More info | Jul 15, 2022 10:30 | #12 For decades - especially when I was back in college - I never had a proper mat cutter. I used a metal ruler, poor box cutter knife and a poor surface; ruined a lot of expensive board. GEAR LIST
sapearl Cream of the Crop More info | Jul 15, 2022 10:33 | #13 If you'd like to see how I cut my mats, here's an old thread from some years back; wish I still had that hair GEAR LIST
Bob_A Cream of the Crop More info | Jul 15, 2022 13:30 | #14 kundurovic wrote in post #19404715 Thanks for claryfing. So the opening should be self made? would it be a problem if image is exact size as opening? The overall paper dimensions of the print have to be a bit bigger than the hole in the mat. Since you usually don’t want to cut off parts of the image when you mat it you print the image with a border. Bob
Jul 15, 2022 16:25 | #15 Does your instructor specify the mat must have a window cut? In my day we mounted them simply to the backing board and submitted them for the project. We'd print the image full bleed or leave a boarder. Back then we bought pre-sized 11x14" mats, window cuts were not necessary for our projects. (Would add to the cost so this helped us save some $ in that regard.)
| Latest registered member is ANebinger 1330 guests, 172 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
