Thread started 28 Jul 2022 (Thursday) 10:13
Seperating a filter that's stubborn stuck...
FrostMonolith
Gallery: 67 photos
Joined Aug 2012
Jul 28, 2022 10:13 |  #1
So I recently bought a secondhand 15-85 online, and it arrived with two unusual conditions:
1. The IS doesn't work (oh well)
2. They gave a UV filter that's stuck, and they did not mention about giving a 'free UV filter' (the thing I want to address)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2022/07/4/LQ_1170913.jpg
Image hosted by forum (1170913) © FrostMonolith [SHARE LINK]
By "stuck", I mean it's as if they put loctite on the threads or something. I really want to remove the dust in between the filter and lens but I still can't take it off. I tried with rubberized worker gloves, didn't work. I fear breaking the thread if I use tongs.
What's the safest practice I can do with this? Will using liquids be okay?
Maybe the world can still look beautiful tomorrow...
T3i/600D | EF-S 10-22mm f/3.5-4.5 USM | EF-S 24mm f/2.8 STM | EF-S 15-85mm f/3.5-5.6 IS USM | EF 70-300mm f/4-5.6L IS USM | Full Weaponry | Old Blog (external link) | Gallery (Facebook) (external link)
PSteven
Gallery: 103 photos
Joined Apr 2011
Jul 28, 2022 10:17 |  #2
I use these cheap filter removing things. I was in the same predicament as you and was happy to find this solution
https://www.amazon.co.​uk …phy-Filters/dp/B093VK591N (external link)
gjl711
"spouting off stupid things"
Jul 28, 2022 10:32 |  #3
There are several methods that work. A filter wrench or rubber gloves, anything to get a better grip helps twist it off. However, I have found that most times when filters are stuck it's because the filter has cross threaded. An easy way to remedy this is very carefully inspect the joint between filter and lens. If at one spot it seems that the gap is ever so slightly closer than the rest, gently using a knife edge, pry the two until you either hear or feel the filter jump back in the right thread. It's subtle but I have had great success using the technique. This also has the positive side effect of not damaging the threads on the lens.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
FrostMonolith
Gallery: 67 photos
Joined Aug 2012
Post edited over 1 year ago by FrostMonolith.
Jul 28, 2022 10:58 |  #4
PSteven wrote in post #19409816 (external link)
Woah, I would have never thought that thing exists! Thanks for telling me, instantly ordered two online!
gjl711 wrote in post #19409818 (external link)
Ooh right, this can be a significant issue. I just checked the threads, looks like everything is as parallel as it can be, but I'll keep that in mind when crossthreading situations happen!
drsilver
Gallery: 900 photos
Jul 28, 2022 11:21 |  #5
Try all that other stuff first, but if all else fails:
  1. Carefully chip the glass out of the filter, watching where the shards go -- down and out is better than down and in.
  2. Blow/brush away any remnants of glass from the lens.
  3. With a pair of needle nose pliers, peel the filter ring away from the lens threads.
  4. Blow/brush away any remnants of glass from the lens.
It sounds a little barbaric, but filters are designed to break to absorb a blow. The frames are really soft -- aluminum or brass -- so they fold up easily under the pliers.
Still, it's crude. You got a lot of sharp, hard things right there by your front element. Again, last resort. I've only done this once intentionally and a couple times after a filter took a blow. Lenses came out fine every time, but I was a little scared every time, too.
Flickr (external link) : Instagram (web)] (external link)
Choderboy
I like a long knob
Gallery: 185 photos
Jul 29, 2022 06:10 |  #6
When trying to remove by hand, the problem is you are mainly only applying a force at 2 spots and you are also compressing the ring, ie trying to force it 'out of round' which works against you. Those cheap filter removal wrenches will apply a fairly consistent force around the entire ring which really helps.
Another way of doing this is to use a flat rubber surface placed on a flat surface. Push down on the lens and twist. This will achieve the desirable even force over the entire ring.
Force will be applied to the front of the ring instead of the side. Even force on the entire ring means much less force required so you should not have to use much force on the lens.
If only using your hands, you can try to space fingers spread around the ring, which creates a more even spread of force. A rubber band on the filter ring works well for grip too.
Dave
Image editing OK
FrostMonolith
Gallery: 67 photos
Joined Aug 2012
Jul 31, 2022 04:58 |  #7
Update to the stubborn filter. As I receive my filter wrenches, I found that they weren't grippy enough, even scratched the filter from the outside, so I literally put some double-sided sticky foam around the wrench to add more grip, and...
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2022/07/5/LQ_1171292.jpg
Image hosted by forum (1171292) © FrostMonolith [SHARE LINK]
...it's finally out! I can finally clean the dust in between!
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2022/07/5/LQ_1171293.jpg
Image hosted by forum (1171293) © FrostMonolith [SHARE LINK]
Was a sticky situation, but thankfully it worked well in the end with no thread damage.
After seperating it, I found some dots that can't be cleaned on the front element of the lens... I guess those are what they call 'fungus spots'? Anyway, thank you everyone for the helps!
paddler4
Jul 31, 2022 08:37 as a reply to  @ FrostMonolith's post |  #8
a clever idea. I'll remember that.
I most often use a heavy rubber band, positioned so that it covers the filter frame but not any of the lens. That usually works.
Check out my photos at http://dkoretz.smugmug​.com (external link)
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Jul 31, 2022 10:52 |  #9
FrostMonolith wrote in post #19410763 (external link)
I wouldn't worry at all about those spots. . I wouldn't worry about the dust, either.
I can't imagine that any of that stuff on the front element would ever have any effect on image quality at all, unless you are shooting directly into a strong light source like the sun. . But even then, with those kind of images you're getting a silhouette, anyway, and aren't worried about finely resolving the detail, so still not a problem.
I used to like my front elements to be clean and free of dust, but soon realized that dust and spots don't make any difference at all, even when I'm pixel peeping, so I don't bother about it now.
bpalermini
Gallery: 197 photos
Joined Mar 2011
Jul 31, 2022 11:34 |  #10
For anyone considering buying a filter wrench I recommend paying a little more and getting this rubberized, metal based set.
https://www.amazon.com …wrench%2Caps%2C​162&sr=8-6 (external link)
I have had the cheaper plastic wrenches and broke all of them. The plastic is not tough enough for a wrench. The metal ones have not had any problems and are still going strong.
Bob
R6II, R6, EF 16-35L II 2.8, EF 24-70L II 2.8, RF 50 1.8, EF 100L Macro 2.8, RF 70-200L 2.8, EF 100-400L II, EF 200-400L 4, EF 1.4xIII, EF 2xIII, 580EXII, YN560IV, RRS TVC23 + BH55, Fuji X-E2, Fuji X30, LRCC, PSCC
My Web Site (external link) | My Sports Portfolio (external link) | Instagram @bobpal
drsilver
Gallery: 900 photos
Jul 31, 2022 15:26 |  #11
bpalermini wrote in post #19410926 (external link)
I was going to mention these. Way better than the plastic ones.
docholliday_sc001
My hypocrisy goes only so far.
Joined Jul 2011
Jul 31, 2022 20:31 |  #12
I've never used a filter wrench, ever, for stuck filters. Just flip a rubber soled shoe upside down, press the lens down hard into the sole, and twist. Fastest and easiest way to remove stuck filters. I've even pulled mangled, out-of-round filters off this way. It puts the most even pressure on the ring, while releasing the thread pressure a bit.
Also works great in the field, just remember to remove the mud from the grooves before using the sole.
FrostMonolith
Gallery: 67 photos
Joined Aug 2012
Jul 31, 2022 21:22 |  #13
Tom Reichner wrote in post #19410911 (external link)
It wasn't a matter of IQ. I just want to clean the previous owner's dirt. I'm not letting any of their mess bother me when I take shots. I'd rather get my dust on it than theirs.
drsilver
Gallery: 900 photos
Post edited over 1 year ago by drsilver.
Jul 31, 2022 22:04 |  #14
docholliday_sc001 wrote in post #19411065 (external link)
How do you get a polarizer off? Those are the ones that get screwed on hastily, twisted around in use, and lock up in the field. More than once I've finished the day with a polarizer just because I couldn't get it off.
docholliday_sc001
Joined Jul 2011
Post edited over 1 year ago by docholliday_sc001. (2 edits in all)
Jul 31, 2022 23:25 |  #15
drsilver wrote in post #19411093 (external link)
I rarely have a polarizer stuck. I typically only use Heliopan ones, with brass rings, and they don't stick much unless you leave a UV on the lens. There's no reason for that, as the pola will also remove UV.
I have had a B+W stuck before and it was the same... mash the filter against my shoe held up against a tree and twist the lens. Took a few extra tries, but the pressure will eventually bind the pola ring and the threaded ring will come loose. Use quick, jerky twists.
The other trick for removing a filter, usually for larger filters, 95, 105, 115mm ones, is to take your belt off or a compression strap off your backpack. Wrap it around the filter, tighten the belt (pull counterclockwise around the lens and against the buckle) or twist the webbing and use it like a strap wrench to remove the filter.
4,306 views & 50 likes for this thread, 20 members have posted to it and it is followed by 10 members.
1455 guests, 110 members online
